B Baxis Member Sep 5, 2014 #1 Tinkering with the van a bit, trying to figure out why it's sitting a bit low. Here's the setup, 05 short 2500 The bump clearance is less than 1/2 " The top spring blocks are different colours white/driver, red/passenger Is this normal? Thanks guys!
S shortshort Dis member Sep 5, 2014 #2 I recall reading here that yes, the colors should be different.
S shortshort Dis member Sep 9, 2014 #4 Something to do with compensating for the weight of the driver. Does your van bottom out over bumps?
B Baxis Member Sep 9, 2014 #5 quite a bit, but since the Konis are bigger and not pressurized, I took them off and put some bs Gabriels and so far so good
