dashboard light show after multifunction switch replacement
skyeg3
After the turn signals stopped working on my 05, we replaced the multifunction switch using hulagun’s instructions here:
https://sprinter-source.com/forums/showthread.php?t=23079
The turn signals worked after install but the SRS light on the dashboard came on. After a half block of driving the ABS, ESP and (TRACTION CONTROL MALFUNCTION INDICATOR) lights also came on. Using a generic scanner from a friend we were able to clear the srs light but the other three remain on. How can I get these other lights off and can it be done with a dad? Or do I need to track down a drb3?
Thank you for any help you can give me.
hulagun
Haulin' A** since 1974
Hi guys, glad you could follow my instructions. Interestingly my van currently has all the same lights showing. It had them before I replaced my MFS though. I was certain that it was due to a bad brake sensor on the right rear wheel because a DAD scan showed a code indicating so. But now I'm wondering if all those lights are due to something else....
:popcorn:
...Using a generic scanner from a friend we were able to clear the srs light but the other three remain on.
That surprises me because most generic scan tools won't access the proper K-line for SRS, TCM, ABS, and other non-engine related systems.
Is the shift lever locked? Do your brake lights work? Maybe the brake fuse opened during the process of your parts changing repair. It should be Fuse #5 under the column. Worth checking anyway. vic
