We borrowed our friends 2004 Sprinter to see if we want to buy it. We have been fixing a lot of little issues to make it safe. We replaced about 10 bulbs so far but there is an issue with the brake lights on the right side in the rear.
Initially the upper bulb (1157) in the housing was working when the lights were turned on but the 2nd filament (brake light) did not light when the brake was pressed. I tested the two contacts and the one contact does not get electricity but not the other. I tested it at the plug that goes into the housing and the wire is not hot. The brake lights on the other side works fine. Unfortunately I introduced a new problem when I touched the test light to ground and the contact that was working and now neither contact has power. I checked the fuses and they all appear to be ok. I am only aware of the fuses on the left side of the driver seat - there may be more.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
