Cold weather starting - best practices
white whale
Engine light / glow plug issue has taught me about cold weather start up and effect on the GP's.
At what temps do you plug in before starting. Idle time or no? Espar heater just as good as block heater? Love the espar!
uglied
uglied
Plug in block heater any time temp is to be below +10 Degress over night. Gives very quick starts and warm up on the road. Also transmission engages quickly and shifts smooth.
TDIDog
Hi, I'm new to this site, and new to Sprinters. I have a 2006 118 Cargo, and wondering if there is a block heater. Where would I find the cord?
jack
Jack
If your van has a block heater you will find it at the back of the block above the exhaust support bracket; last of the three freeze plugs.
Big brass unit with a wire.
surlyoldbill
If you have the espar, there is a mod to make it run on it's own BEFORE attempting to start the engine. I haven't done it yet, but it does sound like a good idea.
cahaak
The Espar mod to run from a switch is a must do if you are in a cold weather region. It is not that hard or expensive. Going on my 5th winter with the mod. It is literally the difference between my wife loving and hating the van (she loves it, won't let me drive it).
Chris
f5hunter
2006 158 SHC 2500 GDE
I have a 250 watt Kats oil pan heater that works well. I also put a 75 watt Kats blanket around the battery and a trickle charger.
That's similar to what I have for pre-heat except no battery blanket.
If you have 120 VAC available then the oil pan heater is non-invasive, relatively inexpensive, easy DIY installation, no wear parts, and effective. It worked great for me. Even with my modified Espar Booster pre-heater I still plug in the pad heater when our temps get to around 0F.
There has been some comment about the NCV3 ECM noticing warm oil vs other temperatures and throwing a code. I haven't had any problem with my T1N nor do I recall any T1N pad heater code comments being mentioned here.
Oilburner
2004 2500 140"cargo l/r
Will drain some coolant only ( for block heater). Oil pan heater is stick on on the oil pan at the bottom, outside. I have it also, but I use block heater- 2 hours of 500 watts and is very warm whole engine.
I am also interested in a lower hose htr due to the difficulty of installing the block htr. Do they work well?
I can't answer your question.
I noticed this as another choice. It connects into the heater hose system rather than the main radiator hose. In about 1/2 hour my modified Espar Booster Heater pre-heats my 2004 engine just fine using the Electric Coolant Circulation Pump. It appears that the OEM pump is not much different than this aftermarket unit. That said, the Espar is about 5000 W output. This add-on heater is much less than that. Still, other circulation heaters are 600 watt or so. Longer circulation time should produce good results.
UH6 600 WATT TANK TYPE ENGINE HEATER DIESEL ENGINE GAS
http://www.ebay.com/bhp/diesel-fuel-heater
I have no experience with either style aftermarket hose connected coolant heater,
