Sprinter SS
I drained 6.8 liters of fluid and pumped back in 7.1 liters. Used all new drain plugs, pan bolts and gaskets. I also used MB ATF 134 for the change. Angled ratchet with Allen head fit sweet.
smiller, you are more than likely correct! There is no indication that the torque converter was ever drained.because they skipped draining the torque converter
Euro parts sd sells kits with everything you need. Great part source.I know this is an old thread but figured I would try. Were is the best place to find the parts you listed in the OP post. Also are there any step by step guides to replacing the ATF fluid on these NCV3 models?
