chromisdesigns
Yep, that should work a treat!Thanks for the suggestion. The three holes in the rear of the black tank are for some cleaning sprayers that George found:
http://www.polywest.ca/#rotacraft
Separate tanks help to keep your dumping process a little more sanitary by using gray water to wash valves and hoses before final rinse with clean water. Just imagine disconnecting the 3” drain hose still loaded with toilet stuff.If it were me, I too would seriously consider a single black/gray tank. Separate tanks have never made a lot of sense to me. The only rational arguments for separate tanks that I have ever heard are:
1) You can dump the gray tank along the side of the road.
2) If your tank overflows, you will end up with less-gross stuff in your shower.
BUT:
1) Who ever does that any more?
2) A Hepvo trap in the shower will keep ALL the gross stuff from sloshing up.
Obviously, for a given amount of space, you will get more capacity out of a single tank. Plus, dumping is greatly simplified. Finally, having all that water in with the black stuff will improve dumping effectiveness.
I would agree in the case of a 3" slinky. But, honestly, I can't imagine using a slinky at all. With a macerator, one typically just screws a cap onto the end of a 1" hose (with the other end permanently attached to the pump) and it doesn't matter what is left in it. At least that is my experience with our 2005 Airstream Interstate, which has a combined tank and to which I added a macerator.Separate tanks help to keep your dumping process a little more sanitary by using gray water to wash valves and hoses before final rinse with clean water. Just imagine disconnecting the 3” drain hose still loaded with toilet stuff.
George.
Ok....If it were me, I too would seriously consider a single black/gray tank. Separate tanks have never made a lot of sense to me. The only rational arguments for separate tanks that I have ever heard are:
BUT:
Ummm... no.Simple solution is to plumb the drain between shower and gray water tank with a "U" in the piping. Make inlet into tank on the bottom not the top. Water in "U" acts as a trap. The other reason for a bottom entry is to minimize the surge effect when stopping. Put inlet in back half of the tank. Surge is higher when stopping than it is under acceleration in a Sprinter. I put the inlets in the correct locations and have not had any surge or smells.
If your inlets are not in the correct location, one method of stopping the backflow into the shower is to purchase a expandable rubber piping pressure test plug and put it in the drain.
FWIW, on my 2005 Airstream Interstate, they solved this problem by installing one of those bathtub drains with an integral plug that toggles open or closed every time you step on it.If your inlets are not in the correct location, one method of stopping the backflow into the shower is to purchase a expandable rubber piping pressure test plug and put it in the drain.
Thank you Hein for great work. I love this HDPE, I don't have to stain it, paint it, edges are finished from the get go and I can use ordinary wood tools if necessary. If I would build another one I could opt for Celtec due to weight.Machining some parts for George's build has inspired me to nail down some final details on my galley/kitchen and start machining some (test) parts. Main reason for the test part is to verify the wall profile for a perfect fit.
George's HDPE parts (below). He laid out the nests of 1/4 and 1/2 thick parts in 2D and specified the edge treatments. I created 3D models, did the CNC programming and ran the parts. Thanks for the business, George.
On my boat I had manually operated shower drain pump with a check valve built in. Some boats have a sump pump. Wouldn't a drain pump be the easiest solution. On my current conversion I have no shower issue, it drains to mother earth or a tray.Simple solution is to plumb the drain between shower and gray water tank with a "U" in the piping. Make inlet into tank on the bottom not the top. Water in "U" acts as a trap. The other reason for a bottom entry is to minimize the surge effect when stopping. Put inlet in back half of the tank. Surge is higher when stopping than it is under acceleration in a Sprinter. I put the inlets in the correct locations and have not had any surge or smells.
'Form Follows Function' or 'Location, Location, Location' are mantras for our needs of shoehorning in a hotel suite in a van.On my boat I had manually operated shower drain pump with a check valve built in. Some boats have a sump pump. Wouldn't a drain pump be the easiest solution. On my current conversion I have no shower issue, it drains to mother earth or a tray.
George.
