OrioN
2008 2500 170" EXT
Here's an option:I submitted a request but won't hold my breath. Cool to look at what some of the Preferred Upfitters are doing/offering.
https://grabcad.com/library/mercedes-sprinter-panel-van
I can tell you where to slice the EXT... as I have one. Basically the D-pillar moves forward 15". On my 'metal', they just added/welded 15" 'pieces' on all 4 sides- floor, roof and walls. I can see the lines in your image.I added the outer body (from the grabcad SW download) to my model. It's a 170 extended and my van isn't so the back doesn't line up. The downloaded model is huge (lots of trimmed and untrimmed surfaces) so it really slows down performance if I try to work with it all shown. I mostly work on the layout model and discrete parts. Only use the top level assembly to check clearances and interferences.
Yep... I was referencing the rear roof panel (w/dimpled rails).Thank you, Orion.
I exported the outside sheet metal from SW as one iges entity. I saw the extension pieces in the SW assembly so should be able to rework that into a regular length van. Those lines you see are the ends of the walls in my model. The rear roof extension is clear to see.
This information is entirely correct. The addition of the filter is exposing you to performance issues and potential failures. Even if the filter has negligible effect when clean, it will be a dust/debris magnet and degrade rather quicky.Adding a filter on the combustion air intake duct could have unintended and unwanted consequences. The filter will result in an increased flow resistance and less air flow through the intake duct than if it were absent. For example, Espar has a limit on max length of intake duct and also proscribes shortening the duct if the routing has a 90 degree bend. I presume this Espar guidance is to limit the flow resistance to ensure that adequate flow can be achieved under design conditions. Too little flow could result in out of spec fuel/air ratios and poor combustion. If your actual intake duct length is, say, the minimum of 8" (my recall without checking manuals) you may be ok with the filter. However, most just tuck the duct either in the cavity along the rocker panel or inside a frame to ensure a supply of clean, moisture free combustion air. Just my two cents.
Beer cold yet?Few more pics from today's effort:
Paint barely dry but couldn't resist dropping in the louvers on the fridge panel.
