BigBassape
Okay, I'm no slouch when it comes to sorting out little problems, but this has got me baffled.
When my headlights or parking lights are on, my left turn indicator on the dash and all my left turn signal bulbs light up and stay lit, no flashing. No headlights or parking lights, the signal works fine.
it started doing it sporadically last week. it would light up for a few minutes when I first turned the lights on, a few minutes later, it would go out, and everything would work normally.
I've replaced every tail, marker and signal bulb. I disconnected each tail light harness, as I did with each front marker light. trying to bypass the short.
I found that my #1 fuse (right side parking lamp) was getting hot. When I remove it, the left turn signal will work with the headlights on. But then I have no marker, or tail lights on the right side. I'm beginning to suspect sorcery.
Anybody encounter anything like this before. I'm at a loss. Short of trying to chase the whole electrical system, I'm not sure what else to do.
thanks!
-g
thanks!
-g
