Engine is boggy out gas pedal let off
pcburnout
Hi All hope someone had same problem and fixed it!
When I let off gas pedal fast and come to stop my engine goes real low on rpms 500 and less and seems to catch it self which causes belt i would say ac to squawk then engine returns to normal idle. Seems to be getting worse as its doing it more often! I would think maybe throttle/ idle sensor is going out if there is one! Hope someone can help its starting to be a problem!
sailquik
pcburnout.
Single A/C compressor or dual with another unit near the back of the van?
pcburnout
single ac what I think its doing is engine is falls below rpm then speeds back up causing belt pull hard on compressor.
