Did LTV explain what the 95 watt factory solar panel was capable of supporting?
A 95 watt panel will deliver ~6 amps into 12 vdc under ideal siting. If you figure the off grid rule of 4 hour averge if good sun per day over the course of a year, it might deliver 25-50 ah of power. 300-600wh/day.
The bugaboo with PV on RVs is that they are seldom ideally sited, (since people tend to seek shade!) they tend to run hot, and ergo less efficiently and people most often over estimate the amont of real sun they get in a day.
In our off grid house, we live on 5-800 WH of power, supplied by 400 watts of PV. On an good day we can see 1.2 kwh of power, but all the PV is aimed well, and is not subject to partial shading. On a really great day, (cold temps, reflection off of snow) we can see 2 kwh.
That 3-600 WH would power a 100 watt tv for 3-6 hoursfor example. By the time you include basic battery chagrin loses (~20%) inverter and wiring loses, (maybe another 15% depending on hardare) might net, 2-400 WH.
Icarus
