!rust under footwells! clean-up under there.
sassmatt72
2006 low top 10 pass
what a mess under mine, with rusty circles in the paint. If I can figure how to post pics I will, but in short I suggest pulling the step inserts. Make sure the drains are clear, mine had gobbs of factory paint/sealant 1/2 plugging the opening.
crazyswede
its on the list to do this summer...figured I'd pull those up and then after cleaning coat the area with POR15 before putting back together
indigoE
Drill an extra drain hole towards the front of the step area... The factory drain hole location is uphill from the low point. I have left my three plastic screw plugs off, because I remove the plastic step to inspect for water whenever it rains. A real nuisance!
