hein
Van Guru
The fixed tray is 10.75 inside to fit a GC2 (6v golf cart) and 20 3/8 outside to fit inside the outboard transverse frame rails ahead of the rear wheels. I'm pretty sure the springs are mounted farther out from the center line on a 2500. One of the things I needed to clear was the forward spring perch and gussets around it. So that might be a problem on the 2500.
I borrowed an empty battery shell to make sure I had measured correctly. I've since added most of the frame details to my CAD model so I can check clearances when the tray swings down.
I looked for 12v batteries for this spot and the only ones I found were very small capacity (low amp-hours). 6V GC2 batteries are the only way to go in this location, imo.
