Data Card Datacard Revealed. I'll show mine, you show yours.
The Traveler
Hi,
New to forum and sprinters.
Can I get a Data card for my 2006, the vin is WD8PD744365927356.
This forum is great and has all kinds of information.
sailquik
The Traveler,
Due to the Sprinter-Source Forum's software restrictions, please send me a PM (Private Message, above the top blue bar, RH side on this page) with your VIN # and a valid return email address.
or send a direct email to:
s8a8i8l8q8u8i8k8 @ 8g8m8a8i8l8dot c8o8m8 (Just remove all the 8's.
I have your VIN # and will have your complete OEM Data Card downloaded by the time you get this.
Actually your Sprinter was built on 03-07-2006, it's white, and it has a 3.727:1 rear end ratio.
Plus about another 50 option codes.
Sorry, I do not post individual OEM Data Cards to an open forum. It's an integrity thing.
After I send it to you via return email, you can do whatever you like with it.
Hope this helps,
Roger.........sailquik
First. Thanks goes to Sailquik Roger and bc339 Bruce for supplying Datacards upon request. Thanks also to those who have posted their Datacards for comparison and helping with decoding some of the information.
There's some information about code definitions here for those that may have missed it.
Thanks to Jon, Jill, et al. I now have a copy of my NAFTA 2004 2500 Data Card. It contains the information of items included when it was built.
The thread is here:
Help with requests to harvest NAFTA datacards for EPC.startekinfo.com
https://sprinter-source.com/forums/showthread.php?t=12923
In looking at my data information I came up with some code explanations which were not included on my card.
Vic's
BB3 No code designation available
TestDataCard
BB3 ELECTRONIC STABILITY PROGRAM (ESP)
Vic's
G40 No code designation available
TestDataCard
G40 AUTOMATIC TRANSMISSION
Vic's
R87 No code designation available
TestDataCard
R87 SPARE WHEEL
Vic's (2004 = XY4?)
XY4 No code designation available
TestDataCard
XY9 MODEL YEAR 9
I learned that "WM0 TELMA-RETARDER CC80" listed on your data card doesn't mean you have a Telma-Retarder.
My card shows no specific alternator amperage. Some other cards I've seen show "M39 ALTERNATOR 14 V / 150 A" and "M49 ALTERNATOR 14 V / 180 A". I ass-u-me that to mean my 2004 came with a 120 90 amp verified (edit: or some other size per Photoadjuster) amp "standard" alternator so they don't specify?
Vic's
J64 Maintenance Indication
I found this added info elsewhere "FOR DRY AIR FILTER" [That is the unit mounted on filter box]
Feel free to add what you know to this thread. Perhaps there is a code list for data cards which didn't show up when I searched from the blue bar. vic
Data Card Info Interpretation
https://sprinter-source.com/forums/showthread.php?t=12943
I also added the link to post #1 in this thread.
GoJohnGo
Road trip!
Here's the one for mine that has some out-of-the-ordinary codes. Wonder how it was to drive without a driver's seat? And that delivery date is June 1, not January 6 (European format is day month year).
Identification number: WD59036621564XXXX 0 VIN: WD5PD64424564XXXX
Datacard
Chassis
Sales designation: 316 KA 4X2 3550
Order number: 7 4 704 37354
Delivery date: 01 06 2004
Paint code 1: 5345 PAINT COLOR JASPER BLUE METALLIC MB 5345
Engine no.: 647981 50 891263
Transmission: 722681 05 197133
Steering: 040612090
Front axle 1: 730415 S 772762
Rear axle 1: 741408 I 106539
Engine
Major assembly variant: X 009 214 450
Front axle 1
Major assembly variant: X 006 800 302
Part var. design.: 7304150
Text ACHTUNG ACHSE OHNE BREMSSAETTEL UND FEDERDAEMPFERBEIN.
ACHSE VL0 1,75TO MIT:
SCHEIBENBREMSE
Rear axle 1
Major assembly variant: X 004 800 193
Part var. design.: 7414080
Text ACHSE HL0 2,2TO MIT:
SCHEIBENBREMSE
VERSCHLEISSANZEIGE S/W
ACHTUNG !! ACHSE OHNE BREMSSAETTEL !!
SA code
172 FUEL PREHEATER
213K No code designation available
580 No code designation available
AC6 AXLE RATIO I = 3.727
B90 WITHOUT LOAD-DEPENDENT BRAKE VALVE
BB0 BRAKING SYSTEM WITH ABS/ASR OR ABS/ETS
BE2 HAND BRAKE LEVER, FOLDABLE
C38 REAR SPRING FOR 3.88-T WEIGHT VARIANT
C43 REAR-AXLE STABILIZER REINFORCED LOWER FRAME
C45 H.D. FRONT AXLE STABILIZER
CE1 ANTI-ROLL SUSPENSION
D91 ROOF DISCONTINUED
D93 ELIMINATION OF PARTITION PANEL
DL1 JAMES COOK POWER TILTING/SLIDING ROOF
E36 CUT-OFF RELAY FOR ADDITIONAL BATTERY
E58 ELECTRICAL COMPONENTS FOR NAFTA TRAILER SOCKET
E88 CIGAR LIGHTER
EE8 12V BATTERY 100 AH
EF7 RADIO SOUND 30 W. SINGLE CD PLAYER AND 2 SPEAKERS
EK1 TERMINAL STRIP FOR ELECTRICAL CONNECTION
ES5 12V POWER SOCKET, INSTRUMENT PANEL
F68 HEATED AND ELECTRICALLY ADJUSTABLE OUTSIDE MIRROR
FG8 CUP HOLDER(S), FRONT
FY6 CENTRAL LOCKING WITH RADIO REMOTE CONTROL NAFTA
H12 HOT WATER ADDITIONAL HEATER
H21 ALL-RND.HEAT ABSORB.GL.W.BAND FLTR ON FR.WINDOW
HH9 SEMI-AUTOMATICALLY CONTROLLED TEMPMATIC A/C
HZ9 HEATER BOOSTER, DIESEL
IL2 EXPORT CODE
IL6 METALLIC FINISH
J11 SPEEDOMETER MPH AND KM/H
J65 OUTSIDE TEMPERATURE INDICATOR
JA1 INDICATOR LAMP FOR WIPER FLUID LEVEL
JK1 "SOFT LOOK" INSTRUMENT PANEL
JW6 ASSYST SERVICE INTERVAL INDICATOR
K60 TAIL PIPE LEADING STRAIGHT TO THE REAR
KB0 MAIN TANK 100 LITER
KL1 FUEL-LEVEL SENSOR FOR AUXILIARY HEATER
KL5 FUEL FILTER WITH WATER SEPARATOR
LB5 CENTER HIGH-MOUNTED BRAKE LAMP
M40 ALTERNATOR 14 V / 200 A
M96 FUEL PREHEATER
MC0 ENGINE OM 647 DE 27 LA 115 KW (156 HP) 3800/RPM
MF2 ENGINE REGISTERED FOR "CARB STATES"
MS1 TEMPOMAT (CRUISE CONTROL)
P08 COVER FOR TRANSPORT
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
Q24 NAFTA TRAILER CROSSMEMBER, TOWING CAPACITY 5000LBS
R65 SPARE WHEEL CARRIER UNDER FRAME END
R87 SPARE WHEEL
RA5 DROP CENTER RIMS 6 J X 16 H2 F. 225/75 R16
RF8 TIRE MANUFACTURER MICHELIN (80)
RG8 TYRES 225/75 R16
RM0 ALL-SEASON TIRE
RM9 TIRE MAKE SPECIAL REQUEST
S90 ELIMINATION OF DRIVER'S SEAT
S91 ELIMINATION OF CO-DRIVER'S SEAT
S99 PASSENGER SEAT FRAME DISCONT.
SA5 AIRBAG DRIVER SIDE
SA6 CO-DRIVER'S AIR BAG
SD2 SAFETY DEV. ON B-PILLAR WHEN FRONT SEATS DELETED
SV0 VELOUR FOR JAMES COOK
T09 LOAD COMPARTMENT SLIDING DOOR SPEC. VER.
T16 SLIDING DOOR RIGHT
V50 ELECTRIC WINDOW LIFTER, 2-WAY
V93 WOOD FOOT FLOOR, DISCONTINUED
W16 LEFT FRONT WINDOW, FIXED IN SIDE WALL/SLIDING DOOR
W17 RIGHT FRONT WINDOW,FIXED IN SIDE WALL/SLIDING DOOR
W23 RIGHT CENTER FIXED WINDOW
WM0 SPRINTER FACELIFT 2003
X42 PLATES / PRINTED MATERIALS ENGLISH
X90 SPRINTER SALES DESIGNATION DELETED
X92 COMPANY LOGO (MERCEDES-BENZ) DELETED
XL8 WEIGHT VARIANT 3880 KG
XY4 MODEL YEAR 4
Y17 PRE-FITTINGS FOR FIRE EXTINGUISHER
Y43 HYDRAULIC JACK
Z29 WESTFALIA CAMPER SPECS., NAFTA
Z41 APPROVAL AS TRUCK
Z75 BODYSHELL REINFORCEMENT
ZU8 USA COUNTRY VERSION
ZX8 DODGE EXECUTION
SA numbers
Group 01
01 522600/02 01 522601/04 01 522602/01 01 522603/07 01 522604/0801 522605/06 01 522611/05 01 522616/08 01 522634/01 01 522636/0701 522638/02 01 522639/01 01 522642/02 01 522644/01 01 522645/03
Group 03
03 522606/02 03 522607/05 03 522608/02 03 522609/06 03 522634/0103 522640/02 03 522641/01 03 522650/04
Group 05
05 522605/06 05 522610/04 05 522619/02 05 522624/02 05 522629/0105 522639/01 05 522642/02
Group 07
07 522612/05 07 522613/08 07 522614/07 07 522617/13 07 522647/1407 522651/09
Group 09
09 522615/10 09 522617/13
Group 13
13 522618/03
Group 14
14 522617/13 14 522620/02
Group 15
15 520059/10 15 522603/07 15 522605/06 15 522622/13 15 522630/0315 522630/08 15 522630/10
Group 18
18 522623/0418 522639/01
18 522625/03 18 522626/01 18 522627/07 18 522629/01
Group 20
20 522628/04 20 522632/02 20 522646/01 20 522661/06 20 522672/07
Group 22
22 522643/06 22 522667/04
Group 32
32 500024/07 32 504039/03
Group 33
33 500021/0433 504007/2333 504304/91
33 500024/0733 504031/0133 530038/01
33 500029/0533 504032/09
33 500323/0133 504032/10
33 504003/0233 504039/03
Group 35
35 504000/0135 504006/01
35 504001/2535 504007/23
35 504003/0235 504008/04
35 504004/0735 504018/01
35 504005/07
Group 39
39 504015/50 39 504304/91
Group 42
42 504000/0142 504016/01
42 504008/0442 504025/13
42 504013/0142 504031/01
42 504014/0242 504304/91
42 504015/50
Group 46
46 504039/03
Other
Rims: KRONPRINZ
Lamps: HELLA/HELLA
Body: 3
nutterbutter
2004 LTV Free Spirit T1N
2004 T1N Leisure Travel Vans Free Spirit 210b. Just bought it at 75k miles. Freightliner grill.
Some bad rusting around top and bottom of windshield, but no signs of black death!
I've learned I have heated mirrors. On a 2004 they turn on automatically as well?
Chassis
Sales designation: 316 4X2 4025
Order number: 7 4 705 78857
Delivery date: 09 01 2004
Paint code 1: 9147 PAINT COLOR ARCTIC WHITE MB 9147
Engine no.: 647981 50 864738
Transmission: 722681 05 027918
Steering: 033503186
Front axle 1: 730415 S 754530
Rear axle 1: 741408 I 089897
Engine
Major assembly variant: X 009 212 012
Front axle 1
Major assembly variant: X 006 800 301
SCHEIBENBREMSE
Copyright Daimler AG , 7/2/15 8:49 PM , EPC 2.1.1.3 DW 06/2015 Delta 2 , User: uie06119 Page: 1
Rear axle 1
SCHEIBENBREMSE
SA code
172 FUEL PREHEATER
C42 STABILIZER,REAR AXLE UNDER THE FRAME
C47 H.D. SHOCK ABSORBERS
D03 HIGH ROOF
E28 ADDITIONAL BATTERY FOR RETROFITTED CONSUMER
E88 CIGAR LIGHTER
FG7 STORAGE BOX AT CO-DRIVER SEAT
FS4 LEFT AND RIGHT AUXILIARY MIRRORS NOT HEATED
Copyright Daimler AG , 7/2/15 8:49 PM , EPC 2.1.1.3 DW 06/2015 Delta 2 , User: uie06119 Page: 2
Identification number: WD290366315615789 0 VIN: WD2PD744945615789
IL2 EXPORT CODE
L65 COURT. LIGHTS F. TRUNK/PASS. COMP. W. DOOR CONT.
L94 ELIMINATION OF PARKING LIGHT
M39 14 V/150 A ALTERNATOR
M96 FUEL PREHEATER
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
R87 SPARE WHEEL
RM0 ALL-SEASON TIRE
S22 DRIVER'S SEAT ARMREST
S25 CO-DRIVER'S SEAT ARMREST
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
SS4 SANTOS FABRIC
V43 WOOD FLOOR
W54 REAR-END DOORS, DOUBLE-WING, OPENING TO SIDE WALL
W73 REAR-END DOOR STEP
WN4 STEUERCODE WERK
Copyright Daimler AG , 7/2/15 8:49 PM , EPC 2.1.1.3 DW 06/2015 Delta 2 , User: uie06119 Page: 3
XY4 MODEL YEAR 4
Y11 BRACKETS USED FOR WARNING TRIANGLE
Y43 HYDRAULIC JACK
Z81 TIE-DOWN EYES
Z90 UNDERBODY CONSERVATION DELETED
ZB6 PRODUCTION PARTS KIT
ZX9 FREIGHTLINER EXECUTION
SA numbers
Group 01
Group 03
Group 05
Group 07
07 522612/03 07 522613/08 07 522614/07 07 522617/13 07 522647/14
07 522651/09
Group 09
Group 13
13 522618/03
Group 14
Group 15
15 520059/10 15 522603/07 15 522605/06 15 522622/12 15 522630/03
Group 18
18 522623/04 18 522625/03 18 522626/01 18 522627/07 18 522629/01
18 522639/01
Group 20
Copyright Daimler AG , 7/2/15 8:49 PM , EPC 2.1.1.3 DW 06/2015 Delta 2 , User: uie06119 Page: 4
Group 22
Group 32
32 500024/12 32 504039/03
Group 33
33 500021/02 33 500024/12 33 500029/06 33 500323/03 33 504003/02
33 504007/23 33 504031/01 33 504032/09 33 504032/10 33 504039/03
33 504304/91 33 530038/01
Group 35
35 504000/01 35 504001/25 35 504003/02 35 504004/07 35 504005/07
35 504006/01 35 504007/23 35 504008/04 35 504018/01
Group 39
Group 42
42 504000/01 42 504008/04 42 504013/01 42 504014/02 42 504015/50
42 504016/01 42 504025/13 42 504031/01 42 504304/91
Group 46
46 504039/03
Other
Rims: LEMMERZ
Lamps: HELLA/HELLA
Body: 3
Speed Racer
2006 2500HC Passenger Van
Vehicle Description DODGE SPRINTER 2500 HC WAGON 140"
Model Year 2006
Body Model VA 2 L 52
Color PCK‐ Orchid Green
In Service Date 05/30/2006
Sales Code Description
B7 Cloth Bucket Seats
AA Gray
ACL Accessory Group
AHT Trailer Tow Group
AJP Power Convenience Group
AMJ Rear Heater Group III
APAS Monotone Paint
AZD Cooling Group
BA6P 150 Amp Alternator
BDCS 100 Amp Battery
BGKS 4‐Wheel Anti‐Lock Brakes
BNBS Electronic Stability Control
BNMS Traction Control
CDBS Reclining Front Seats
CDXS Driver & Passenger Headrest
CD1S Rear Seat Cupholders
CD3S Center Instrument Panel Cupholder
CFBP 1st Rear Bench 3 Passenger Seat
CFDP 3rd Rear Bench 3 Passenger Seat
CFYP 2nd Rear Bench 2 Passenger Seat
CGES Passenger Air Bag
CGTS Driver Air Bag
CKZS Rear Rubber Floor Covering
CLUS Front Rubber Floor Covering
CSRP Front Passenger Assist Handle
CS1S RT Sliding Door Assist Handle
CUAS Driver Seat Armrest
CVLS Left Side Passenger Seat Storage
CV4S Front Ash Tray
CV7S Passenger Seat Armrest
CV9S Rear Ash Trays
CWE Right & Left Rear Seat Armrest
CWFP Left Rear Seat Armrest
CYZS 10 Passenger Seating
DGZ 5‐Speed Auto W5A380 Transmission
DMES 3.72 Rear Axle Ratio
EX8 2.7L I5 Turbo Diesel Engine
GBES Windshield w/Filter Band
GEC Front Left Side Sliding Window
GEW Front Right Side Sliding Window
GFAS Rear Window Defroster
GKAS Right Sliding Door
GLFS 270 Deg Opening Rear Hinged Doors
GNQS Rear View Day/Night Mirror
GTBS Power Heated Mirrors
GXRP Keyless Entry
HABS Air Conditioning w/Auto Temp Control
HBDP Rear Heavy Duty Air Conditioning
HDBP Front Auxiliary Heater
HDC Rear Auxiliary Heater
HGM Insulation ‐ Front
HGRP Insulation ‐ Rear
JFHS Tachometer
JFJP Outside Temperature Gauge
JJAS Cigar Lighter
JJJS 12V Power Outlet Mounted in IP
JPAP Power Windows
JPBP Power Locks
LAFS Driver's Seat Belt Warning System
LAJS Headlamps On Warning
LBGP Front Reading/Map Lamp
LCHS Rear Dome Lamp
LCKS Front Dome Lamp
LMAS Halogen Headlamps
LMK Daytime Running Headlamps, High Beam
LPAS CHMSL Lamp
MCCS Gray Front Fascia
MCQS Rear Bumper ‐ Gray Fascia
MEGS Rear Mud Flaps
MEJS Front Mud Flaps
MG4S Dodge Badge
NAS 50 State Emissions
NEPS Rear Extension Exhaust Pipe
NFWS 26 Gallon Fuel Tank
NHBS Auxiliary Transmission Oil Cooler
PCK Orchid Green
QCKS Orchid Green
RBE AM/FM Compact Disc Radio w/Chgr Ctrl
RCBS 2 Speakers
SBAS Power Rack and Pinion Steering
SCFS 4‐Spoke Steering Wheel
SHAS Front Heavy Duty Stabilizer Bar
SHCS Rear Stabilizer Bar
TBBS Full Size Spare Tire
TBNS Underslung Tire Carrier
TU4S 225/75R16 BSW All Season Tires
TZHP Michelin Brand Tires
WDGS 16X6 Steel Wheels
WLBS Steel Spare Wheel
XAXP Timer
XEGS Hydraulic Jack
XELS Tool Kit
XEYP Trailer Tow Wiring Harness
XFRP 5000 lbs. Receiver Hitch
XFYS Fire Extinguisher Prep.
XFZP Sender Fuel for Auxiliary Heater
XWHS Warning Triangle Bracket
YAAS Build To U.S. Mkt. Specifications
batilzown
2003 T1N 2500
Batilzown Datacard
2003 2500 Fraightliner
172 FUEL PREHEATER
5524 No code designation available
936K No code designation available
C38 REAR SPRING FOR WEIGHT VARIANT 3,880 KG
D50 PARTITION PANEL FULL-WIDTH
E88 CIGAR LIGHTER
EK1 TERMINAL STRIP FOR ELECTRICAL CONNECTION :crazy:
F76 GRAB HANDLE CO-DRIVER SIDE
H01 HEAT INSULATION CARGO AREA/PASSENGER COMPARTMENT
H04 HEAT INSULATION DRIVER CAB
Identification number: WD290366215534161 X VIN: WD2YD642235534161
Copyright Daimler AG , 1/8/16 12:14 AM , EPC 2.2.1.0 DW 01/2016 , User: uie06119 Page: 3
H15 SEAT HEATER FOR FRONT PASSENGER
H16 SEAT HEATER FOR DRIVER
H86 TIMER FOR HEATER BOOSTER
IL2 EXPORT CODE
J61 HYDRAULIC BRAKE TEST CONNECTION
JW0 BACKUP WARNING SYSTEM
L05 AUTOMATIC DAYTIME RUNNING LIGHTS FOR USA/CANADA
L62 READING LAMP
M96 FUEL PREHEATER
MF1 LOW-EMISSION ENGINE AS PER CFFP (NAFTA)
MQ6 ENGINE OM612 DE27 LA 115KW (156HP) 3800RPM
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
R87 SPARE WHEEL
RM0 ALL-SEASON TIRE
SS1 VENICE SEAT COVER FABRIC
T85 ENTRANCE GRAB AT CORNER PILLAR AT LEFT REAR
T86 ENTRANCE GRAB AT CORNER PILLAR AT RIGHT REAR
Copyright Daimler AG , 1/8/16 12:14 AM , EPC 2.2.1.0 DW 01/2016 , User: uie06119 Page: 4
V43 WOOD FLOOR
VA3 LOAD COMPARTMENT INNER TRIM UP TO ROOF WASHABLE
XY3 MODEL YEAR 3
Y43 HYDRAULIC JACK
Z81 TIE-DOWN EYES
ZX8 DODGE EXECUTION
rjz5400
Well the main odd thing is I seem to have a "416 " model. I don't know what that means really. also I was surprised to have the lower gear ratio, happy about the milage. 20-21.5
Identification number: WD290466215520465 8 VIN: WD2YD442135520465
Copyright Daimler AG , 1/15/16 6:55 PM , EPC 2.2.1.0 DW 01/2016 Delta 1 , User: uie06119 Page: 1
Datacard
Chassis
Sales designation: 416 4X2 3550
Order number: 7 3 705 25220
Delivery date: 04 04 2003
Paint code 1: 9147 PAINT COLOR, ARCTIC WHITE MB 9147
Equipment: 1330 No code designation available
Engine no.: 612981 50 747696
Transmission: 722681 04 413532
Steering: 030873149
Front axle 1: 730411 S 674558
Rear axle 1: 741130 X 418849
Engine
Major assembly variant: X 009 207 351
Front axle 1
Major assembly variant: X 006 800 109
Part var. design.: 7304110
Text ACHTUNG ! ACHSE OHNE BREMSSAETTEL UND FEDERBEIN.
SCHEIBENBREMSE
Copyright Daimler AG , 1/15/16 6:55 PM , EPC 2.2.1.0 DW 01/2016 Delta 1 , User: uie06119 Page: 2
Rear axle 1
Major assembly variant: X 004 101 643
Part var. design.: 7411300
SA code
172 FUEL PREHEATER
494 No code designation available
D03 HIGH ROOF
E88 CIGAR LIGHTER
EF5 RADIO SOUND 10 WITH CASS.PLAYER AND 2 SPEAKERS
IL2 EXPORT CODE
Copyright Daimler AG , 1/15/16 6:55 PM , EPC 2.2.1.0 DW 01/2016 Delta 1 , User: uie06119 Page: 3
M96 FUEL PREHEATER
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
R87 SPARE WHEEL
RF1 TIRE MANUFACTURER CONTINENTAL (10)
RG0 195/70 R15 TIRES
RM0 ALL-SEASON TIRE
RS2 DROP CENTER RIMS 5.5J X 15
V43 WOOD FLOOR
XY3 MODEL YEAR 3
Y43 HYDRAULIC JACK
Z81 TIE-DOWN EYES
Copyright Daimler AG , 1/15/16 6:55 PM , EPC 2.2.1.0 DW 01/2016 Delta 1 , User: uie06119 Page: 4
SA numbers
Group 01
01 522600/03 01 522601/02 01 522602/01 01 522603/06 01 522604/05
01 522605/02 01 522611/02 01 522616/03 01 522634/01 01 522636/02
01 522638/02 01 522639/01 01 522642/02 01 522644/01 01 522645/01
Group 03
03 522606/02 03 522607/04 03 522608/02 03 522609/05 03 522634/01
03 522640/02 03 522641/01 03 522650/02
Group 05
05 522605/02 05 522610/02 05 522619/01 05 522624/02 05 522629/01
Group 07
07 522612/02 07 522613/06 07 522614/06 07 522617/09 07 522637/01
07 522647/02 07 522651/06
Group 09
09 522615/07 09 522617/09
Group 13
13 522618/01
Group 14
14 522617/09 14 522620/02
Group 15
15 520059/17 15 522603/06 15 522605/02 15 522630/01 15 522630/02
15 522630/03 15 522630/04
Group 18
18 522623/04 18 522625/01 18 522626/01 18 522627/01 18 522629/01
18 522639/01
Group 20
20 522628/01 20 522632/01 20 522646/01 20 522661/05 20 522672/02
Group 22
22 522643/04 22 522667/02
Group 32
32 500024/03 32 504039/02
Group 33
33 500021/02 33 500023/02 33 500024/03 33 500029/06 33 500323/03
33 504003/02 33 504007/01 33 504019/02 33 504031/01 33 504032/03
33 504032/04 33 504039/02 33 504304/06
Group 35
35 504000/02 35 504001/05 35 504003/02 35 504004/07 35 504005/07
35 504006/01 35 504007/01 35 504008/05 35 504012/03 35 504018/01
35 504019/02
Group 39
39 504015/50 39 504015/92 39 504019/02 39 504304/06
Copyright Daimler AG , 1/15/16 6:55 PM , EPC 2.2.1.0 DW 01/2016 Delta 1 , User: uie06119 Page: 5
Group 42
42 504000/02 42 504008/05 42 504012/03 42 504013/02 42 504014/03
42 504015/50 42 504015/92 42 504016/02 42 504019/02 42 504031/01
42 504304/06
Group 46
46 504039/02
Other
Rims: LEMMERZ
Lamps: HELLA/HELLA
Body: 3
diredesire
2004 2500 140WB
Met up with autostaretx several weeks ago - he encouraged me to get/post my data card. Thanks sailquik for obliging. I haven't analyzed this dump at all:
Identification number: WD290366215708100 6 VIN: WD2PD644045708100
Copyright Daimler AG , 1/31/16 11:15 PM , EPC 2.2.1.0 DW 01/2016 Delta 2 , User: uie06119 Page: 1
Datacard
Chassis
Sales designation: 316 4X2 3550
Order number: 7 4 704 42788
Delivery date: 08 09 2004
Engine no.: 647981 50 956827
Transmission: 722681 05 615352
Steering: 042453187
Front axle 1: 730415 S 827269
Rear axle 1: 741408 I 144825
Engine
Major assembly variant: A 647 010 06 00
Part var. design.: 64798150
Text FUER DIESES FAHRZEUG KANN ALTERNARIV DER RUMOFMOTOR A647010044580 GELIEFERT
WERDEN
FOR THIS VEHICLE THE BASIC ENGINE A647010044580 CAN BE SUPPLIED ALTERNATIVE
LY
Front axle 1
Copyright Daimler AG , 1/31/16 11:15 PM , EPC 2.2.1.0 DW 01/2016 Delta 2 , User: uie06119 Page: 2
SCHEIBENBREMSE
Rear axle 1
Major assembly variant: X 004 800 436
SCHEIBENBREMSE
SA code
172 FUEL PREHEATER
D03 HIGH ROOF
E88 CIGAR LIGHTER
Copyright Daimler AG , 1/31/16 11:15 PM , EPC 2.2.1.0 DW 01/2016 Delta 2 , User: uie06119 Page: 3
FZ9 TWO ADDITIONAL MASTERS
IL2 EXPORT CODE
J64 MAINTENANCE INDICATOR FOR DRY AIR FILTER
L62 READING LAMP
M96 FUEL PREHEATER
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
R87 SPARE WHEEL
RM0 ALL-SEASON TIRE
SS4 SANTOS FABRIC
Copyright Daimler AG , 1/31/16 11:15 PM , EPC 2.2.1.0 DW 01/2016 Delta 2 , User: uie06119 Page: 4
V43 WOOD FLOOR
XY4 MODEL YEAR 4
Y43 HYDRAULIC JACK
Z81 TIE-DOWN EYES
ZX8 DODGE EXECUTION
SA numbers
Group 32
Group 33
Group 35
Group 39
Group 42
Group 46
46 504039/03
Copyright Daimler AG , 1/31/16 11:15 PM , EPC 2.2.1.0 DW 01/2016 Delta 2 , User: uie06119 Page: 5
Other
Rims: LEMMERZ
Lamps: HELLA/HELLA
Body: 3
In message #6 of this thread, member BenJohnson posted an address of a site that will provide your DataCard on the screen for free: http://carinfo.kiev.ua/cars/vin/mercedes/vin_check
Yes, it takes you to a site in Kiev. But it does work.
(for a fee, he'll send you a PDF file of the data)
This might offload some of the impact upon sailquik (who does the pdf for free :hugs: )
For the curious, the german text on the Westy listings (such as #44):
ACHSE VL0 1,75TO MIT: SCHEIBENBREMSE
(google) translates to:
ATTENTION AXLE WITHOUT BRAKE ASSEMBLY AND SPRING COUPLER.
AXLE VL0 1.75TO WITH: DISC BRAKES
the second bit:
SCHEIBENBREMSE
becomes:
AXLE HL0 2,2 WITH:
DISC BRAKES
WASHING ADAPTER B / W
CAUTION !! AXIS WITHOUT BREMSSAETTEL !! (but we've already learned that to mean: BRAKE ASSEMBLY )
JBECK
Could I Please get a data card for My new project WD2PD744145692673. I'm having trouble figuring out what parts to purchase for the engine rebuild, and tune up kit/hoses. The intake manifold is 647, it has an electronic actuated turbo, I don't see a low pressure fuel pump. Head is stamped with A612012320 040603. Engine # 6120110201 on the block.
sailquik
All,
Since Sikwan (our Super Moderator) updated the website server software, I no longer need an email address
to send back the Full OEM Data Card.
The new Server software handles the multi-page .pdf files with no issues at all.
Regards,
Roger (sailquik)
Roger,
I added your "All" note to post #1 and post #19.
Thanks for your continued help. :thumbup:
