Hello Dr A,
By looking at the valvoline max life spec, I see it spec for mb 234.10 thru 16. Is this atf fluid suitable to use on 06 sprinter?
Product Information
A PRODUCT OF VALVOLINETM INC.
MAXLIFE™ Multi-Vehicle ATF
Valvoline™ MaxLife™ Multi-Vehicle ATF is a full synthetic formulation with advanced additives to prevent the major causes of
transmission breakdown and help extend transmission life. Developed to help prevent leaks, maximize transmission performance,
reduce transmission wear, and maintain smooth shifting longer than conventional fluids. It is suitable for use in a broad range of
ATF applications including most Ford, GM, Toyota & Honda models as well as Dex/Merc, Mercon LV and many more applications.
Valvoline has conducted extensive in-house testing, independent lab testing, and field-testing to support MaxLife™ Multi-Vehicle
ATF performance in the broadest range of transmissions; however, it should be noted that MaxLife™ Multi-Vehicle ATF is not an
OEM licensed product. The respective vehicle manufacturers have neither evaluated nor endorsed MaxLife™ Multi-Vehicle ATF in
these applications. If an OEM licensed product is preferred we recommend Valvoline DEXRON® VI, Valvoline ATF+4® and Valvoline
MERCON®V for the corresponding applications.
The Valvoline MaxLife™ ATF Advantages:
Synthetic fluid
Conditions transmission seals to help prevent leaks
Reduces varnish formation and wear
Our best anti-shudder performance
Improves and maintains smooth shifting longer than conventional automatic transmission fluids
Superior anti-shudder performance
Provides excellent flow properties at low temperatures and greater film protection at high temperatures
Helps maximize the life of higher mileage transmissions
Performance Levels
Suitable for use in:
Allison TES 389*, C-4
Audi/VW G-055-025-A2, G-052-162-A1/A2, G-052-990-
A2, G-055-005-A2, G-055-162-A6, G-055-540-A2, G-060-
162-A2, G-052-025-A2, G-052-162-A1
BMW LT71141, LA2634, M-1375.4, ATF 3.0, 7045E, ETL
8072B
Chrysler Diamond SP-III, NAG-1, 3403 M115
Ford MERCON®* (in California use Valvoline Dex/Merc)
Ford MERCON® V*, FNR5*, XT-9-AMMF5*, (in California
use Valvoline MERCON V)
Ford MERCON® SP*
MERCON® LV
GM 9986195
GM DEXRON® II, III and VI
GM Autotrak II
Honda/Acura ATF-Z1, DW1 (except in CVTs)
Hyundai SP-II, SP-III, SP-IV, SPH-IV,
SP4-M, SP-IV-RR
JWS 3309
JASO 1A
KIA SP-II and SP-III Fluids, Red 1
Mazda M-V, FZ
Mercedes Benz MB236.1, MB236.6, MB236.7, MB236.9,
MB236.10, MB236.12*, MB 236.14*, MB 236.15*
Mercedes Benz NAG-1
MOPAR AS68RC ATF
Miscellaneous OEMs – M1375.4, M1375.6, L12108, LT 71141,
ETL-7045E, ETL-8072B, 3403 M115, N402, AW-1
Mitsubishi Diamond SP-II, SP-III, ATF-J3, Dia Queen ATF-PA
Nissan Matic-D, Matic-J, Matic-K, Matic-S, Matic W
Saab 93 165 147
Subaru ATF
Subaru ATF-HP
Toyota / Lexus Type T, T-III and T-IV
Toyota WS
Volvo 1161521, 1161540, STD 1273.41, 97340
VW TL52162, LT71141
ZF TE-ML-14B, 16L, 17C
*Please note that legislation in California prohibits Valvoline from recommending MaxLife™ ATF in certain applications where the
viscometrics of MaxLife™ ATF do not match those of the official OEM specification. Valvoline therefore does not recommend the
use of MaxLife™ ATF in these applications in California.
Valvoline does not recommend MaxLife™ Multi-Vehicle ATF for use in most continuously variable transmissions (CVTs) and in dual
clutch transmissions (DCTs) unless specifically noted, nor in automatic transmissions where Ford Type F fluids are recommended.
Valvoline stands behind all of its products, including MaxLife Multi-Vehicle ATF. Use of MaxLife™ Multi-Vehicle ATF in
transmissions where recommended by Valvoline WILL NOT void the vehicle’s warranty. In the unlikely event that you or your
customer experiences any transmission issues while using MaxLife™ Multi-Vehicle ATF in a Valvoline recommended application,
