Don't know for sure, but it should be behind where all the fuses are located. It typically is a metal brown box with a piano hinge to open the top part revealing circuit breakers and fuses for the coach side of things... AlDoes anyone know where the house charger /converter is located on the Thor Citation Chateau Sprinter 24SA?
I'm planning to replace it with an inverter/charger and can't seem to find it.
Mailman- You have responded to a post from 2016... But welcome..
I have a Thor Siesta 24ST- The Coach batteries are charged by the converter when plugged into the 120 volt. They should also be charged by the alternator when the engine is running. Check the USE/STORE switch , usually in the step well.
The chassis battery is usually not charged when on shore power.
I believe the Winnebago Sprinter models are wired differently and do charge the engine battery on shore power.
