Diesel Generator "Low Power Engine" fault code.
DonK
Not sure what this means nor to correct it! Generator will start and run for about 20 seconds and shuts off. Thought I had air in fuel system and allowed lift pump to cycle twice without starting. Still starts and goes off after 20 seconds with the above code in control panel. Fuel tank is full also and tried new fuel filter.....still doing same. :idunno:
icarus
Not familiar with this particular model,, but does it have a low oil shut down? Either low oil or a bad sensor would be my guess.
Icarus
K-9 SPRINTER
K-9 SPRINTER
billappleton
FYI, anyone reading the message, I had the same problem turned out my fuel tank was just too low. Filled it up and gen ran fine ")
MeRob
Any chance that you might have a 'foreign object' that that is plugging the the fuel line after 20 seconds of drawing fuel... that then unplugs / clears itself after the fuel draw ceases ? ie maybe at the fuel inlet in your fuel tank? or ?
