Graphite Dave
Dave Orton
14 ga. 304 SS Tank is 8" wide x 9" tall x 36" long and holds approx. 10 gallons. There are two 1" inlets for the sink and the shower. One on rear end and one on the side. Both inlets are welded close to the bottom so when tank has water in it the infeed hoses will act as a trap. 1" heater hoses will be used to connect the drains to the tank. There is a 4" x 8" cleanout hole on the bottom covered by a 6" x !0" 10 ga. plate. A 1/2" vent elbow is welded at the top of the side and in the middle of the tank.
The tank will be bolted to two 8" long pieces of 80/20. The 80/20 will be bolted to the Sprinter floor support ribs on the left side in front of the rear wheel. 80/20 will be on one side of the rib and a 1/4" x 1 1/2" x 6 1/2" SS plate will be on the opposite side of the rib. Rib is sandwiched between the 80/20 and the 1/4" plate. Two 5/16-18NC x 3" carriage bolts will pass through the rib at each end of the tank.
The outlet is a 3/4" half coupling. There is a 3/4" ball valve and then a quick disconnect hose coupling.
The tank tucks up inside the Sprinter side so no part of the tank is visible from the street.
