Hey George-Thank you for the compliment.
I have no problem with microwave. My problem was that to have a DC powered microwave the necessary DC infrastructure is complex and expensive, about $1000 extra. The primary use for the 1000W inverter in my application is microwave, for PC or mobile devices a small 300-500W would suffice. Doing it again I would install 3-4 stage charger such as Xantrex TrueCharge and 300-500W full sine wave inverter. With a different loads requirement my story would change. Simply, building 1000W supply from the batteries can’t be justified in my usage of microwave in off shore power situation, I do have inside mounted alcohol stove.
Regarding 80/20, during the last Sprinter Fest in Tualatin I discussed the plywood versus 80/20 with a person who introduced himself as an owner of the cabinet shop. He stated that to get the same strength of cabinetry work he would need to use ¾” plywood in a mobile application, so:
- 2’x3’ 80/20 1515 frame is 9.36 lbs. which can be filled by 1.8 lbs double wall polycarbonate, 4.7 lbs plywood, or 6.6 lbs HDPE
- 2’x3’ ¾’ plywood weighs 14 lbs.
- To reduce 80/20 weight you can use sometimes none or light weight panels or lighter profile 1” extrusion which is one half weight of 1.5” one.
The benefits for 80/20 are:
- Very strong frame versus strength coming from panels.
- Combination of 80/20 with HDPE requires "0" finishing, for me this was a key point. HDPE can be cut or machined with wood tools such as miter or table saw, forstner drill bits, or router.... HDPE is very often used in the boating industry.
Regarding cutting at home, in my entire project I made just 1 extrusion cut on the miter saw using special blade for nonferrous material at home. All modules I designed on CAD and factory cut them to size. I know it is more expensive but it is still way less expensive than buying Airstream with platinum bolts. There is a learning curve with 8020 materials and fasteners, I would suggest to look at some of their videos. If you are reasonably proficient with CAD - assembly is simple. Cutting and tapping at home is definitely doable in a limited in tools garage but learning curve gets steeper. Hein’s CNC help was significant on this project.
Good luck,
George.
I keep coming back to the clean look of your design. I'm still slowly getting a handle on all of the components and terminology. If I'm understanding this correctly, you were able to have 80/20 make all (or the majority) of your cuts and supply all (or most) of your fasteners? I'm doing a pretty basic conversion, and I really like the look of your galley and overhead cabinets. Do you happen to have a design/drawing and parts list (to order from 80/20 for the galley and overhead that you would be willing to share? That's a Dometic sink, correct? Very nice.
