expcourier
expeditious
So I was getting a loud whine underneath the vehicle and decided to replace the carrier bearing. I hope the photos and write ups give you the confidence to do this yourself. It is really not that difficult and with a couple of inexpensive tools from Harbor Freight and some elbow grease "YOU CAN DO IT"
First I marked the driveshaft position on the axle and differential as well as the transmission output shaft, just use a crayon. I'm not sure that this was necessary but why not put it back the way it came out.
Second remove the front hanger called the retaining bracket using an 18mm socket.
Vehicle on ramps one side to allow easier access to driveshaft.
