jdcaples
Not Suitable w/220v Gen
First the tire info:
On 9 October 2007 I swapped the stock Continental tires for a set of Michelin LTX AT/2s. I kept the stock tire on the spare rim. Specs can be found here.
I'm happy with the tires. They're stickier than the OEMs. There is one corner in Seattle where - with the OEM tires - the Sprinter's traction control system always engaged. It's a steep right turn to a very steep incline. If I had to guess, I'd say it's maybe a 20% grade(?). THe Michelin's don't break loose.
I don't notice any more road noise with the Michelins at highway speeds. My fuel economy hasn't changed. I'm running the factory listed pressures in all 4 corners.
One thing I did notice: The Tire Pressure Monitor System did not reset until I'd driven about 5 minutes on the new rubber. It did list some amazingly incorrect numbers:
The drivers side listed 42 PSI on both front and rear, while the passenger side listed 67 on both front and rear corners. I used the reset functions, but it was eventually self-correcting. Since this was the first modification I made to the vehicle's factory equipment (preceeding the toupee by a couple of days), I was anxious.
Surface corrosion on the rotors
I'm including two photographs in this post. While the wheels were off, the service techs didn't seem to mind my shutterbug habit. I noticed some rust on the two front rotors.
Should I clean that off and (carefully) apply some paint, or should I just ignore it?
-Jon
-Jon
