Sound 5 - Connect to Aux in!
anomaly
The first part of this process is to order the Aux in cable kit from Becker
part # BNA-1319, cost $16.40 plus shipping (Total cost ~$25USD)
You'll also need a cable to connect from your MP3 player headphone jack to the Aux In kit. You'll need a 1/8" Male to stereo RCA Male like this one
Next, see my posting about pulling the stereo from your dash:
If you're interested, take a look at the wiring diagram for this stereo
Now - let's get down to business!
Surprisingly, the kit was not already wired up - apparently the same kit can be used with multiple head units, so you'll need to connect the wires yourself.
Take a look at the parts that come "in the box"
In addition, the kit includes some helpful instructions
Here's a closeup of the cables in the kit
Pull the stereo out of the dash
Here's the diagram of the pinout needed for this project
anomaly
Here's where the plug will fit in when we're done
*WHEW* - it fits perfectly!
The tricky part here is making sure that the wire is inserted properly. Putting it in wrong makes it HARD to remove from the blue wiring block, so exercise caution!
Note that the pins on the back of the stereo are aligned horizontally, and you'll want to align the wire so that the connector lines up to slide on the pin.
First, connect the yellow wire - note that while the photo looks like the blue plug is pushed all the way in, it's NOT - if you push the blue plug all the way in at this stage of the process, it will be difficult to get the wire seated properly in the connector.
This is the Left + connection
Next hook up the brown wire
This is the common ground for both channels
Finally, hook up the red wire
This is the Right + connection
Now it's ALL hooked up!
anomaly
Now it's time to hook up the iPod.
Grab the RCA cable
Hook up to the Aux in kit (match colors)
Now it's all hooked up!
Now, how do I get the stereo to switch to Aux in? See page 93 in the radio handbook:
Press the leftmost bottom button until the display reads AUX.
Turn the Volume knob until the display reads AUX ON
Then you'll hit the CD button when you want to listen to your MP3 player!
anomaly
Now it's time to run the wires through the dash. First, i tried putting it in the Glove box, then I finally chose to run it out the front of the dash.
Here's how to run the cable to the glove box:
Open the glove box
Push up on the latches on the top of the box
Let the glove box fall open
If you're careful, and have a small enough arm, you can push the wire from the center hole in the dash over to the glove box. Reach up with the fingers of your right hand through the hole the latch to catch the end of the wire.
Pull the wire through the round hole in the middle of the glove box.
Once you've grabbed the wire, pull it out and close the glove box. 18 Jack in box.jpg
Now you're ready to reconnect the RCA jacks to the Aux in, then close up the dash
anomaly
There's plenty of room for the wires in the dash.
Gently guide the wires on the left behind the stereo as you slide the head unit back into the dash.
Reconnect the RCA cables
Here's a good hole to use for snaking out the headphone connector
Here's my iPod in the dash - ready to run!
biggy herm
This is awesome! Thank you so much. I am in the process of hooking up my sirrius radio, now I can use my ipod too.
Tuono
Thanks for the writeup! I did a quick-and-dirty version of this by just cutting the RCA plugs off a standard stereo cable like the one you used, and soldering on female connectors to fit the correct pins on the radio (sheathed in heat-shrink tubing). Good to go! Thanks again!
:cheers:
anomaly
iPod connection to Sound 5
So, this week my wait was over. I finally received "iPod interface part# 1678.299" from Harman Becker parts.
This product is available from them for $136.50 plus shipping.
This week has been really nuts at work, and I've been dying to give this a shot.
I had high hopes about this, despite the following info in the Becker Great Britain site:
The Becker Remote Kit lets you control your iPod(r), conveniently select
titles from your music library via the car radio display and enjoy
top-quality sound. Compatible with 3rd and 4th generation iPods(r), Mini
and Photo iPods(r).
The following products are iPod(r) compatible:
Mexico 7948 (starting system-cd 3.5)
Mexico 7942 (starting system-cd 3.6.1)
Cascade Pro 7941(starting system-cd 3.5)
Cascade 7944 (starting system-cd 2.5)
Traffic Pro 7945 (starting system-cd 2.5)
Traffic Pro 7949 (starting system-cd 2.5)
Indianapolis Pro 7950, 7952, 7953, 7955 (starting software version 3.0)
Indianapolis 7920, 7922, 7923, 7925 (starting software version 2.0)
Grand Prix 7990, 7992, 7993, 7995
Mexico Pro 7936, 7937, 7938, 7939
So I finally hooked up the unit tonight. Pretty smooth, and the iPod began to charge as soon as I plugged it in. I went through the menus on the stereo to configure the Aux input from Aux in to CDC. At that point, the stereo did not see a CD changer. :thumbdown:
BUMMER!
What I did discover is that if I switch the stereo back to Aux in mode, I could listen to the audio. So what I get for the price of the adapter is an easy hookup from my iPod dock connector, the ability to charge the iPod, and only one wire hooked up to the iPod (not a headphone jack and a power adapter.)
I've been thinking hard about whether to hook up the iPod through the GPS unit, whether to mount the iPod on the dash and use the headphone connector, mount the iPod on the dash and use the dock connector to charge and get audio out.
I'm still on the fence. At this point, given that the cable I have in hand makes a fairly elegant connection.
Is it possible that I still need to do something to get the Sound 5 to recognize the iPod as a CD changer?
Interested in hearing your thoughts....
anomaly
Pretty cheap!
No magic in the aux in kit from Becker - that should work just fine to connect directly to the pins on the back of the stereo.
Looks like a pretty cheap option - your cable was only $29.
I'm dreaming of buying a video ipod and adding video to my van someday, so I may go for the cable with the video connection too. It's $59, but still much cheaper than the Becker option. The only real upside to the Becker kit is the ISO block connectors and pin s are included in the Aux in kit, and if you buy the iPod cable, there's literally no wiring to do at all - just plug and play.
For my money, ending up $80 cheaper to buy the installer.com cable is worth the hassle of doing my own wire connections.
Thanks for the tip - I had not looked around on the net for an ipod dock connector cable. I shopped in stores, but never considered looking for a supplier like them. Did you buy from them? Were they easy to deal with? Keep their commitments?
anomaly
Re: Pretty cheap!
Took them a couple of weeks to get it to me, but I got the cable installed tonight.
So far, I'm pretty happy with this - I tapped into switched power and the same ground as the stereo, and now I've got a single cable connecting my iPod to my Sound 5. I can power and recharge the iPod and listen to the audio through the head unit.
I think I'm done hacking (for now.) I've got iPod and bluetooth integrated to the Sound5. A real win!
Next project - sometime down the road - will be adding video to the van.
anomaly
Can you please tell me which wire is switched power. Thanks
Oh yes. I forgot that not everyone who reads *this* thread will not have read *all* the threads I have posted. I confirmed that there are no switched power lines to the Sound 5, or on that harness.
I also installed a Parrot 3100 bluetooth unit, and for that I needed switched power.
I re-used the line that I tapped from the cigarette lighter to provide switched power for the iPod adapter.
To tap the cigarette lighter wires, you'll need to remove the whole unit. No screws, just 4 clips, two on each side of the unit. Note that removal of the drawer which holds the cupholder is insufficient, and also gives you the opportunity to dig around looking for the two tiny springs that come loose when you pull it out.
If you slide a trim tool on either side of the unit, you will release the clips and be able to slide the whole thing out. It's a VERY tight fit, and requires some finesse. Also, it's important to note when replacing the unit that it will take some force, but if you brute force it in place, you risk breaking the tiny plastic rails that align the unit.
I have some photos of that process, and can post them if you think that they will help.
Does the installer.com cable need to be on a switched power line, or can be on an always-powered line? The Sound 5 harness must have an always-powered line because you can use the radio with out a key in the ignition. The ability to charge while the key is out would be great.
I have ordered the BNA-1319 from Becker, but would really like the ability to charge to iPod in the van too. I have 2 Sprinters and we use the iPod at our worksites and the battery drains in less than a day usually.
anomaly
No magic here. The power can either be switched or unswitched, and it should work fine. Of course, you take the risk that you'll run your truck battery dead with that approach, but you'll have no trouble making it work.
