311 cdi no start
4x4 rob
Hi im having troubles with my 311 cdi 2001 i have replaced the head after being sat up for 18 months due to a cracked head
shes gone back together with 4 new injectors and ive put new seals on the fuel regulator on the rail
i cant get her to fire or run! on cranking its developing 108 bar fuel pressure im not sure if this is right
also there are no stored error codes
is the pressure correct?
do the injectors require codeing the are guenuine bosch ones?
any ideas would be great as im pulling my hair out
cheers Rob
Eric Experience
Rob.
18 months ago did the engine stop itself or did you switch it of? are the glow plugs heating? To check valve timing try a very small spray of ether. Eric
