skwoodwiva
This is my 2nd of 3 runs. 2 runs for 10 sec, & 15 for final.
I use 1/8 id edit- less than, silicone. 4" equals 1ml (measured).
The 1st, through out, the 3rd, I filled each "well" where the orig fitting sits to the brim then when inserting the hose the level would come up about 1/2 to 3/4 " so each was marked as zero.
I spite of #4 being so much out of the pack it is still only edit, 1.1ml or so ml for 15 sec. In the 1st pic 10 sec it is about 1 ml.
Edit actually, test 1(10 sec), comparing to 3 (15 sec) is right on. .7 ml for # 4 injector
Note being such a small ID the scale is way exaggerated.
Has anyone cleaned their bad ones w/ some of the purge products & repeated the test? Like Wynns, BG or Liqui Moly.
