teammontana
2003 2500. I wanted to put an electric oil guage on so had to tap into 12v, aux 12v, and dash light circuit. Spliced into 12v and aux circuits under driver seat and was looking for a wire for night light [checking the side marker light on left side by mirror] when I noticed the turn signals did not work, nor did the hazard lights. I took the fuze strip off under the steering wheel and found no apparent problems. The relays I have switched to determine that the turn signal relay is ok and the turn signals still don't work. There is 12v across the fuze for the hazards so they should be getting power. Now the top bolt on the fuze strip won't come off to check it again. The oil guage works fine, except for a night light [still working on that], but no turn signals. Can't find any fuzes blown anywhere and eveything else seems to be working fine. The only other symptom I have is that the left headlight low beam won't work if the back of the headlight shell is off but will work with it on. Any ideas? Supposed to be leaving tomorrow for long trip. Thanks, Larry H
