Tire pressure question
Micky
Hi. i have 225/65/16 on allesio alloys my 216 cdi weighs in a bit over 2800 kg can anyone halp me with tyr pressures, Micky.:idunno:
sikwan
06 T1N Can
Hi Micky:
What is the maximum tyre pressure written on the sidewall of your tyre?
And what brand of tyre do you have?
Without the information above, I can only give you what the tyre pressures are recommended for your Sprinter, which will probably be wrong.
loredo_sprinter
I have the Michelin a/s LT 225/75/r60 , the Sprinter is the 2005 hightop passenger/ 140' . I go with 55psi in the front and 80lbs in the back. I'm a shuttle driver here at the airport and at times I can get a lot of weight back there
Jules
Micky
Hi Micky:
Tyres ar dunlop and max psi is 71 Micky
AzteK
Blah Blah Blibbidy Blah!
I keep my fronts at 65 and rears at 70. if im going to carry something real heavy, i'll pump up the rears to the 80
