sikwan
06 Tin Can
Window quit at a bad time? Need a no part fix? This is it.
Of course while prepping for a trip and leaving tomorrow the driver side power window on the 2006 decides to break the nylon mount.
I did the bend the arm "temporary" fix trick. It may be a permanent fix for a 15 year old Sprinter. It was a 30 minute job only because an on foot traveling salesman selling cleaning products interrupted the operation. (I thought I had been transported back to the 1940's. I did buy a bottle of his snake oil cleaner to reward his entrepreneurial methods... and to get him to move on.)
This is a power window Youtube video. It shows the trim removal and the bend trick to get a power window working after the plastic slide cracks.
The lock cable doesn't need to be removed for the bend trick.
I used 2 pipe wrenches to slightly kink the arm. A tool bench handy 8" and a 14" size. The arm can be bent without the pipe wrench leverage, but the wrenches made it easier. The arm needs to be "kicked" enough to keep the actuator arm bearing against the track. That keeps the metal button engaged without needing a nylon slug. The manual crank windows use a metal button slide. There is no plastic/nylon slug like is on the power windows.
A possible factor for the plastic slide breaking?
The windows in the 2006 are rarely ever 1/2 way open. Typically they are fully open or fully closed. Today while running errands the driver side window was 1/2 open. After a couple stops I noticed a bit of noise from the window when the door was closed, but didn't think much of it. Did the plastic happen to fail, or was there additional stress added because the arm was loose at a 1/2 way position? I guess that we'll never know for certain.
Post #12
sprinter-source.com
I trust that Sikwan won't mind me adding this T1N window regulator quick fix Youtube video here.
Basically.
Remove top pillar trim by pushing/tapping the lower section toward the vent window.
Remove the pull handle cover trim.
Remove switch assembly and unplug connectors.
Find 2 ea. T30 screws and remove. (One is in a deep and narrow recess.)
Unlatch lower storage hatch and swing open.
Grasp door panel and pull straight up to release clips.
For driver side power window:
Struggle to release the switch connectors past the latch cable.
For passenger side power window:
Easily work the single connector free past the door latch cable.
For lubing I just balanced the door panel on the open hatch door. More extensive work might require freeing the latch cable to completely remove the panel.
Bend the operating arm in enough to get the actuator stub to engage the track.
Re-assemble in the opposite order.
Sikwan's original thread begins here.
A couple weeks ago I heard a rattle coming from the passenger side door. I've never heard it before so I just powered the window up and the noise went away. 15 minutes later when I parked the van, I tried to close the window but it wouldn't move.
It would move up a bit, but it wouldn't go back down. Great, another thing to fix before the trip. Hopefully it won't be too hard.
Here's some info on removing the door panel...
https://sprinter-source.com/forums/showpost.php?p=1136&postcount=4
This is what I found when I removed the door panel...
The white plastic in the window channel split into "a" and "b" leaving "c" disconnected.
I measured the plastic piece and it was 0.625 in height.
I found a post from Vic (Thanks Vic!) that someone used a shower door roller that was 0.625 in height to fix the power window problem. Problem was I could not find any 5/8" roller at any of my local hardware stores. I had to order a set online from Home Depot and had them expedited.
When I got the roller, I went ahead and modified it with a Dremel and sanding bit. With the OEM (cracked in half) plastic on hand, I grounded the roller until it matched the original and it fit within the window channel.
Original roller, modified roller, and OEM plastic.
It was real close on the metal part.
Now to drill out the riveted part.
I laid a piece of cardboard down to catch the shavings.
Post #12
Lube Grease Window Track and Parts
Greasing the window tracks without cleaning the old grease out has worked great. I didn't realize how much the 2004 crank windows were binding until the new grease freed everything up. I ass-u-me that the result is the same for the 2006 powered windows, but I don't really have a way to verify...
Basically.
It would move up a bit, but it wouldn't go back down. Great, another thing to fix before the trip. Hopefully it won't be too hard.Here's some info on removing the door panel...
