that set up looks really cool! which area in the van is this?
really nice install and major props!
also is that power box - is this.... like all in one or? do you have a manufacturer and part number?
I'm in Tucson, the Growatt 48v charger inverter is an all in one unit. I used it primarily because of size and weight. (27lbs.)
It's ok, but the programming is vague and it can't charge from the AC side and the DC side at the same time, so I am having to use upconverters to use the big alternator as a second string of panels in parallel with the actual panels to charge from the alternator.
A separate charge controller like the outback FM80 would be better, but takes up too much room and weighs about 15lbs.
Here is a pic of the gear that got stuffed in the box. The 2kw 12v inverter is to act as the "grid" for charging when there is no solar.
It works, but the upconverters will be better.
