elemental
Finished installing front grab handles (driver and passenger sides). Although a parts list was previously published on the forum, I opted to just buy the Terrawagen kit for $149. It provides all of the necessary parts, and some of the necessary tools (the grab handles in the kit appear to be Mercedes factory parts). I liked getting all of the parts together, easily, but I think the value of the supplied tools was marginal. I'm pleased with the overall results as shown in these photos:
Note that the Terrawagen kit includes plugs for the Torx bolt holes to refine the appearance; I just haven't stuck mine on yet.
The issues I ran into:
- The supplied 9 mm drill bit didn't drill cleanly through the sheet metal - could have been my technique. I ended up using an Astro Rivet Nut Hog (PN 9456) to clean out my first two drilled holes on the passenger side, and to completely drill the holes on the driver's side. The Rivet Nut hog is a step drill bit with steps specifically sized for popular rivet nuts. Step 5 is a 9mm diameter hole for M6/SAE 1/4" rivet nuts. I liked the results I got from the Rivet Nut Hog.
- The supplied DIY rivet nut installation tool (an M6 bolt, an oversized nut, and several washers) apparently takes some finesse that I wasn't able to muster for my first attempt. Despite my trying to be careful in the amount of torque I applied, the rivet nut was compressed but bulged funny on the face. The compression wasn't perfect, so the barrel wasn't quite at 90°. I wanted to try the DIY tool despite having a pneumatic rivet nut tool (AstroPnuematics PRN1) because I've read how great they are for small batches of rivet nuts. Perhaps it gets easier if you practice, but I didn't have extra rivet nuts to practice with. I managed to (mostly ) straighten out the first rivet nut and installed the other three rivet nuts with my pneumatic tool (a pull not spin tool). Much cleaner results (flat rim and 90° barrel with full compression).
- The supplied 1/8" pop rivets didn't fit into the holes drilled by either of my two 1/8" drill bits. According to references I found online, a machinist's #30 bit drilling a 0.129 to 0.133" hole should be used for a 0.125" rivet; if you buy one just buy a stubby to decrease the possibility of going through the other side of the door frame. I didn't buy one, and since a 9/64" bit (which I did have) drills a 0.140" hole (too big) I opted to gradually clean material away from the sides of the hole with my 1/8" bit. It worked, but wasn't great form.
- I coated the raw metal created by drilling with Rustoleum Enamel, flat black. This added considerable time to the installation process since I had to wait for the enamel to thoroughly dry. I had to repeat the painting process for the pop rivet holes since I assumed the pop rivets would fit after I drilled the holes and painted the too-small holes, then had to repeat after I enlarged the holes.
- I used 3M 5200 when installing the rivet nuts to improve moisture lockout and adhesion. This also increased the process time since I had to wait for it to dry.
- I found it easier to get in/out using the grab handles than without them, especially on the passengers side. I've been in the habit of just grabbing the wheel on the driver's side.
- My wife (shorter than me) found the passenger side to be easier than grabbing the dashboard tray the way she normally does.
