Graphite Dave
Dave Orton
Electrical is done from shore power plug to the distribution panel. Solar panel and Morningstar MPPT controller is installed and operating. Two duplex plugs are powered with inverter supplied 120 volt power. All seems to work correctly. 120 volt power is grounded to the chassis in 3 places. 12 volt system is not grounded. Because I am not connecting the house and vehicle batteries together for charging, I did not ground the 12 volt to the chassis. All 12 volt ground wiring is routed back to the negative bus. The second 1000 watt inverter (vehicle) has not been installed. I am thinking of designing a new passenger seat base that contains the second inverter, a seat swival, outlets for 12 volt power and 120volt inverter power. The 120 volt sine wave wiring from the vehicle inverter is not installed. The selector switch that allows selection of shore 120 volt power or vehicle inverter 120 volt power is installed. The battery is a 255 amp-hr Lifeline with spade terminals. The terminals were the right choice. The Magnum inverter/charger is silent. All the electrical is located on the left side of the van above and around the rear wheel well under a bench seat. The 8D battery does fit behind the wheel well if it is raised up 3 3/8" above the floor. The battery has a hold down angle on top, is contained by the 3/8" plywood panel on seat front and has wood strips in front and back on support plywood base to limit front to back motion. The parts selection was good except for the IOTA IDP 30 distribution panel. I would use separate 120 volt and 12 volt DC panels if I did it again. All wiring is being done with "SO" cord without conduit. I did use blue plastic conduit in two places: support of solar panel cord at ceiling and up through the body at the right rear to get 12 volt power up to the lighting on that side of the van. All other wiring is surface mounted in Panduit 1 1/2" square wireways. The Panduit will only be seen on wall behind drivers seat for a short distance. Since all wiring is accessable and not buried in the walls I can add whenever I want. There are four rocker switches above the distribution panel. Two will be used for rear heater fan and the water pump. Two are spares. All 12 volt lighting will be switched at the fixture.
Also attached is the latest electrical diagram of the system.
