I’ve read about those stupid people who put gasoline in their diesel tank by mistake. I just knew I was too attentive to ever do something quite as dumb as that. I pulled into the station I frequently use. The gasoline and diesel fill nozzles are on the same pump. Gas is black, diesel is green. Gas is on the left, diesel is on the right. So I swipe my card, pull the handle and start pumping. “Wonder what the price is today… $3.79, not bad… oh sh*t.”
Let go the handle. 0.879 gallon of gasoline is now in my tank. Hang up gas nozzle. I was wool gathering…. distracted…. in deep thought. Nope, it appears I am stupid. I must be because that is what I thought about this happening to others.
0.9 gallons… 25(+) gallon tank. About 5% petrol contaminations if my math is correct. Glug in some Power Service additive, fill tank with diesel, rock Sprinter back and forth, add almost another 2 gallons after that. Drive home with no apparent engine performance issues. Add a pint of TCW3 2 cycle outboard motor oil. Rock Sprinter back and forth again to mix. (Now any neighbors who are watching me are absolutely convinced that I’m nuts.)
Searched the internet to see how much trouble I’m in.
Well, it depends on who you believe. Some of the adamant ones say any gasoline and I’m screwed with a newer design diesel. Others say that up north people actually add gasoline to diesel for extreme cold conditions. I found a couple that said anything around a 5% contamination should be fine, but adding a bit of TCW3 2 cycle outboard engine oil will help with any loss of lubrication.
So I decided to ride it out. Here are some stats so far.
0.9 gallons petrol added accidentally.
Filled to top off (25 gallon)
3.6% concentration of petrol.
Added Power service and 1 pint of 2 cycle TCW3 oil to help combat possible lubrication loss by petrol.
At approx. 100 miles I added 4 gallons diesel for dilution.
@ approx. 3.6% concentration I figure I had 0.75 gallon petrol left in 21 gallons.
The 4 gallons diluted that down to around 3% petrol.
120 miles added 4.7 gallons diesel. (Fuel neck still smelled of petrol at 3%.)
@ approx. 3% concentration I had 0.6 gallon petrol left in approx. 21 gallons
The next 4 gallons diluted me down to around 2.5% petrol.
Added another pint of 2 cycle TCW3 oil.
125 miles added 4.9 gallons diesel.
@ approx. 2.5% concentration I had 0.48 gallons left in approx 20 gallons.
The 5 added gallons diluted me down to around 1.9% petrol.
Added some glugs of Power Service Diesel clean.
136 miles added 5.4 gallons diesel fuel.
@ approx. 1.9% concentration I had 0.38 gallons.
The added 5.4 gallons diluted me down to around 1.5% petrol.
Added some glugs of 2 cycle TCW3 oil (big bottle), then added a couple more.
Interestingly I can still smell petrol at the fuel fill neck with that approx. 2% concentration. It may be contamination hanging in the filler neck though. I'm surprised at how many 5 gallon fills it's taken to get to 1.5%. Checking the gross math it basically works out though. (Math is not my strong suit.) I started with about 3.6% concentration at 25 gallons. After adding about 20 gallons of new fuel I'm at about 1.5% now. Rough numbers I know. Anyway, that helps show what it takes to dilute out a tank of bad fuel.
My sincere apologies go out to those people I previously thought were stupid. vic
Based upon the data that I have from my one gas in the tank misadventure, I'm convinced that the electric fuel pump can be used to empty the tank enough for a top off of good diesel to dilute the gas to acceptable level. (For the OM612 suck pump a small electric fuel pump can be connected to the fuel filter inlet hose.) The gallon or so heel left in the tank is diluted by 25 gallon diesel top off.
EDIT: Some condensed information copied from the more complete Post #81 in this same thread.
An Overview of Removing Gas Petrol from a Diesel Tank
Thanks goes to Lindenengineering Dennis.
From Dennis. For diesels with an in tank fuel pump.
VS30 Note for Tank Drain
Per Lindenengineering Dennis there is no fuel pump relay for VS30 Sprinters. The fuel pump is controlled by the ECM aka ECU. Multiple key on/off cycles to power the fuel pump are limited with a wait time imposed after a few cycles. Draining a VS30 fuel tank could require a tank drop, or needs an added fuel pump or syphoning method.
A recent comment.
Confirmation that the fuel tank can be effectively emptied using the fuel pump.
The only thing that I would add for the procedure is that it might be worthwhile to grab a quart of TCW3 2 cycle oil while at the store getting fuel containers. That will help to offset any loss of lubricity which can be a factor of gasoline addition/contamination.
The thread is here. Thanks goes to Fishermunn.
https://sprinter-source.com/forums/showthread.php?t=23886
Edit: Another thought...
The T1N fuel pump relay is under the driver seat. Someone with a bit of electrical knowledge and a jumper wire could pull the relay and run the fuel pump directly. That will avoid the fuel pump timeout and the need to cycle the key off and on.
The fuel relay location.
The fuel relay pin designations.
Note: Have all hoses and containers in place before installing the jumper wire.
Some NCV3 specific fuel pump relay info is here.
https://sprinter-source.com/forums/showthread.php?p=331624#post331624
P.S. - The Sprinter fuel pump to empty the contaminated tank idea will not work with OM612 diesel engine Sprinters. They have a mechanical low pressure fuel pump, not an electric pump.
PM Info said:Here are 2 each inexpensive fuel pumps either of which which I believe can be used to empty the tank on your OM612 engine with mechanical suck pump. You may need to prime these pumps, but once they are pumping they should pretty much empty the tank. (Approx. 30 gallons per hour.)
W8sunjs Universal 12V Heavy Duty Electric Fuel Pump Metal Solid Petrol 12 Volts
http://www.amazon.com/W8sunjs-Unive...8?s=automotive&ie=UTF8&qid=1455933891&sr=1-12
Hilitchi Universal 12V Low Pressure Gas Diesel Inline Electric Fuel Pump (Model:HEP-02A)
http://www.amazon.com/Hilitchi-Univ...8?s=automotive&ie=UTF8&qid=1455934062&sr=1-30
As always, clicking the blue arrow icon within the quote box will take you to the original thread.If there is significant injection hi pump damage due to mis-fueling, the metallic evidence will typically collect and be visible at the return fuel line's diverter valve.
On the 612, this plastic diverter valve is located on the top of the fuel filter.
On the 647 this valve is located just above the fuel cooler at the rear of the tank.
The 612's valve is somewhat easier to access and inspect because it only has 2 fittings and clamps. The 647 has 4.
Doktor A
Added:Well I wrote the post in abstract based upon limited info and so much like any post & its written information.
Now from experience putting gasoline in a diesel fuel tank isn't the end of the world as some might suggest.
Essentially gasoline has the same molecule train as diesel, just rearranged differently so it doesn't burn too well.
So you get an acrid exhaust stink & limp mod-ing.
Really boiled down its what you do to the engine & its FIE system. That means what immediate steps are taken to rectify the issue using the term sooner or later! Later being the operative word here.
My business has done "oudles "of these "repairs" and the real beneficiary is our shop's waste oil heaters.
We have set procedure, and a hose with a male barbed adapter. Attached to the main fuel line, and then cycle the ignition switch auto pumping the tank out until its as "dry" as you can get. That will leave about 2 gallons dwelling around the pump bucket "tops".
It take an average about 20 minutes to empty it.
Then bung in a good lubricity additive like BG245 or Stanadayne Performance Plus, followed by a full ish tank of diesel. Any residual gasoline will be diluted to no real concern.
Throw out the fuel filter(s)--& replace!
One on a Sprinter, Several on other brands and do a quick rail & line purge plus bleed up, preferably using a fuel pressure to see what pressure we get from the lift pump working.
If its to spec don't sweat the small stuff!
Go for a fire up and then a test drive .
In 999,9999% of the time it will be fine, BUT we did encounter one specimen that was driven about 250 miles, ignoring the loss of power !
Now that did the injectors & HPOP in, and we couldn't raise rail pressure to enable a start.
So again the word LATER is operative here!
So a fixed shop rate of 2,5 hours, one fuel filter (Sprinter) , one bottle of additive, & 20 gallons of DERV.
Not a serious wallet dinger!
The real issue is water & crap in bunkered fuel at gas stations!
Now that really does do expensive damage in a short space of time and a real wallet flusher!
But that is something else & quite a different set of circumstances prevailing.
Added:The Drill!
Did this last week in a Dodge dealer parking lot.
Disconnect the hose at the filter , and attach a 8ft length of 3/8 fuel hose plus 3/8 barb to the open hose.
Place hose in 5 gallon jerry and have at least 5 cans available if the tank is full.
Switch in ignition to power up the instrument pack, and this will power up the in tank pump for 16 to 30 seconds .
Repeat the switch on, switch off, switch on procedure until you have drained the entire tank.
Bung in 5 gallons of fresh DERV [diesel fuel], and pump through a further half to one gallon or so.
Change the fuel filter, connect up, [top off with fresh fuel] and switch the pump on through 3 cycles then go for a fire up.
All too easy
A recent comment.
The BG 244 or 245 is the most expensive option & we use it religiously when the fuel has been diluted with gasoline or water as a Hail Mary after having purged the fuel system out and filled with fresh DERV.
To answer
Yes Stanadyne Performance plus takes some beating on price, dosing and availability,
We have known it to clear a plugged DPF --Much to our surprise.
Both are good products with positive customer revues .
