T1N: 1994-2006 2006 T1n 118” camper build 75,000 miles
ubersmurf
Vehicle Location
Seattle, wa
Contact Info
Message
Price
51000
Firm/OBO/Auction
Price is Firm
Model Year
2006
Mileage
75000
Photos too big to upload, can be seen on marketplace add
Rare very capable combo of windowless 118” wb high roof with exceptionally low miles (75k) and zero issues. Coastal off-road bumpers front and rear + upgraded wheels, tires, suspension, and limited slip differential . (About $12,000 invested making this short wheelbase diesel van the most offroad capable 2wd van around) As these things often do, the cost was ultimately a good bit higher than I anticipated. I’m not in a hurry to sell. If it hasn’t sold by July 2027 I might get flexible with the price. Firm until then
All work done in the last 6000 miles
-Quaife Limited Slip Differential professionally installed inc. rear diff service
-Bilstein B6 Front struts and rear shocks
- 2 Tone UPOL Raptor Liner paint job inc. door jambs + around windshield (gasket permanently removed) Interior painted in mastercoat sound deadener paint (negligible improvement but at least the silver is nicer than white. Between the mastercoat and raptor, the entire body was painted except the engine bay and a small amount of the firewall.
There was minimal rust when i bought the van, all superficial but everything was sanded down, treated with rust converter and painted over with multiple coats of a rust proof solution.
-2x 700mm x 300mm arctic tern windows
-Coastal offroad Aluminum front bumper w/ winch attachment + 4x40 watt pod lights (included but not installed). I chose aluminum for the front bumper to save 45lbs. The bumper also comes with an additional steel cross member that bolts to the frame and offers real protection vs the virtually useless plastic factory bumper. I wanted something to protect my investment in case of a collision with an animal or other vehicle.
-Coastal offroad rear bumper steel with dual swingouts with full sized spare tire w/ locking lug nuts and hanging 2 bike rack attachment. Still allows access to built in hitch.
-Fresh oil change + transmission service/filter
-Passenger swivel seat
-Electrical system is easily accessible, fully 12v with 200ah renogy lithium battery, victron charge controller, 400watts of flexible renogy panels on roof, blue sea fuse block
-130 liter Dometic NRX 12v fridge ---Massive capacity, very quiet and efficient. One of my fav features)
-High mount custom back up camera
-Tinted driver and passenger windows (make a big difference with heat, ive been considering getting the windshield done as we'll
-10 gallon water capacity + faucet with 4’ pullout hose for showering via the window
-Comes with commonly needed spare parts (fuses, filters, timing belt)
-Firestone destination x/t 215/85r16 tires + Romac Stealth 16x6.5 wheels. I carefully selected this combo for the lightest weight while retaining full strength and capacity. 37lbs per tire + 20lbs per rim really helps efficiency and driving performance. I run 45psi but you could run lower for a smoother ride. The larger size offers a noticeable lift for offroading + puts the engine in its sweet spot rpm wise. Cruises at 75mph happily at 3000rpm.
-Tons of easily accessible storage capacity + room for more if you wanted to do overhead cabinets.
-Privacy curtain + windshield thermal shade
-12v lights on dimmer switch and fan
-Cabinets built with baltic birch ply, and 3 coats of polyurethane finish. ¾” bamboo ply counter tops
-Vevor diesel heater installed under passenger seat. Everything connected except tapping into the factory auxiliary fuel line.
-Aftermarket head unit with apple/android carplay
-Currently at 75,000 original miles. Runs perfect, never seen engine temp above 200, cap dance test hardly moves. Zero known mechanical issues. Gets 24-26 mpg every tank even with build out, all personal gear, larger wheels and tires + bumpers. Over 600 miles of driving range
-72” x 48” fixed horizontal bed with comfy 5” mattress. I am 6’2” and slept comfortably. I purposely did not finish the upper walls or ceiling to maximize standing and sleeping room
I just returned from a 4000 mile road trip across Canada, Montana, Colorado, Utah, and Oregon. Drove up to 11,200 ft in elevation and a fair number of rough roads and some stream crossings. Van did fantastic. Plenty of power, ground clearance, and traction.
How is the bed fixed to the vehicle? Any support beams or just directly to the wall?
There is 3” angle aluminum (1/4” thick) bolted with heavy duty hardwear into the wall running the full width of the bed and the cross pieces rest on that. The 3” angle is permanently affixed and the rest of the bed can be disassembled in a few minutes.
total stack height is 1” + mattress so it really maximizes the underbed storage and bed head room height.
Back
