haasenpfeffer_93
Planning ahead to a cross country road trip next summer and wanting to eliminate as many things as possible that could fail and be a pain to replace on the road. Wanting to do a preventative replacement of my stock in tank lift pump and would love to convert to a an external motorsports style Bosch pump while keeping the factory pickup and sump system.
Looking at the ubiquitous and proven Bosch 200 series but it's a good bit higher pressure than needed at around 80psi. My question is how picky would the factory low pressure system be on the om647 - ie does it have to be exactly in that 60psi range or would higher pressure maybe be ok? Or would i need to do Bosch 200 then an external regulator set to 60 psi? That would of course put the bosch running at its max pressure or using its internal relief valve all the time which wouldn't be ideal
