I have a 2010 513 Sprinter motorhome that goes into limp mode occasionally and sometimes quite often. I can drive 1000kms. or more with no dramas and then limp mode or drive 20kms. and then limp mode. The fault code is P226300 boost pressure deviates from the specified value. The vehicle pressure and smoke tests ok. Intercooler hoses have been replaced, turbo replaced and charge pressure sensor at turbo replaced. Is it possible there is an intermittent problem in the ECU. This has been going on for a while and is very frustrating. Thanking you in advance for any ideas.
