The cable itself? CAN wires are just wire, 0 ohms resistance.
A quick lesson about cable impedance.
Cable impedance is the result of a cable's distributed capacitance along the cable and its distributed inductance along each conductor canceling each other out at AC frequencies. These are both AC phenomena and the resulting relationship is simply a measure of Volts to Amps, so cable impedance is measured in ohms.
The inductance and capacitive reactances are related to the conductor size and the distance they are from the return path (e.g. a wire conductor, cable shield or a ground plane). This is a property measured at AC frequencies that doesn't show up on a standard (DC) ohmmeter.
If cables didn't exhibit an AC resistance at each end, no transmitter could send a signal very far down a long cable. It would act like a large capacitance and little or nothing would go through. But since it acts like a resistance, it allows power to be transmitted to a load (or antenna) that closely matches the cable impedance.
DC resistance is different, since AC capacitance and inductance effects are not measured. Any transient behavior because of those effects has decayed away, and that is what your ohmmeter measures.
Interestingly, 50 ohm coax cable is a compromise. Minimum signal losses occur around 77 ohms, so cable TV uses 75 ohm coax cable. Maximum power transfer occurs around 43 ohms, and transmitters usually use 50 ohms, which gives reasonable transmission loss while still moving lots of power to the load. Why we ever used 300 ohm twinlead on TV antennas up to the 1970's is a mystery, but likely due to the antenna and impedance of free space.
CANBUS is 120 ohms, largely due to the wire size they decided on. They're not transmitting lots of power and not going very far, so this becomes more of a cost driven decision.
And don't worry, the test on this will be open book.
