AH64ID
2025 AWD 144HR
See this is why got confused. I appreciate all the responses.
I am currently 50 front and 65 rear and the ride is a little harsh. My tires are oversized so that helps. I will try dropping them down into the 40's to see how it feels. For long highway trips I will return to my current pressures to help with heat. For washboard roads I'll drop to 35 and try that.
Thanks everyone!
Drop to charted pressure for the weight, it’s enough even for long highway trips.
For washboard roads you can go even lower since you aren’t traveling at speed. The chart pressures are for the weight at the tires speed rating, so when you’re driving below the tire speed rating you don’t need as much air. Be sure to air up before hitting higher speeds
The tire pressure charts are a joke. Run those pressures on the highway for a couple hours and see where your temps are at, it won’t be good. A larger size tire should support the same weight at a lower pressure, I wasn’t able to keep the temperatures in check without running full pressure.
You’re approaching GVWR. Why not run the tires at the specified pressure and address the suspension as the issue
I think something else was going on, I’ve run tire pressure chart pressures for nearly 20 years on all kinds of rigs (jeeps to 3500’s) and never had any tire run anything close to as hot as you’re mentioning, temps are always in check without running max pressure unless I’m at max load for the tire.
