ESP Variant Codes
Parker 84
Need Help changing ESP variant codes
Purchased a van that had the abs pump assembly swapped and has shifting issues and a 567D faulty variant code. My friend has a launch scanner that will let you select variants but will not change them. We can set the correct tire size and then go to set wheelbase and the tire size moves back to 15" and van length to short.
What scanner is capable of resetting the variants.
