Water pump
What Next
I changed the water pump around and also put on a kit to make it quieter. I put a little plastic lid under it as a base so if any water leaks I can see it. also if you look close on right side you will notice a clear line with silver end on it , this screws to the brass adaptor on the intake line. It takes just over a gallon of the pink stuff to fill lines come winter.
