I believe I gather enough info from fellow members to make this happen. Since the ECU has been bench tuned, I spoke with the tuner, and they agreed to delete the "software" side and I'll be doing the "hardware" side on the driveway.
My plan is to remove ALL the components related to the delete. Replace the DPF/CAT with straight piping (hopefully it won't resonate terribly) Unless a member recommends a straight pipe with resonator is the best option from previous experiences. Remove the EGR and cooler completely is also the plan. Fabricate end caps on the downpipe, and intake.
But here is the dilemma, a pressure sensor and oxy sensor will NEED to be placed back for proper operation. Of course the new downpipe will have the bung for the oxy sensor.. What about the pressure sensor that is on the cooler. Should this sensor be placed in its original location , somehow. Or can it be threaded on the fabricated end plate on the downpipe. I read a commment from IVAN that close to the turbo, the heat exposure eventually will damage the sensor.
please let me know of any work-arounds, suggestions..
John A
John A
