Increasing tongue weight capacity on a Sprinter
bigb
2011 Winnebago Via 25Q on 2010 3500 Tucson, AZ
Mercedes says maximum tongue weight when using weight distribution on a NCV 3500 XD is 750 lbs. There are receiver hitches sold for the Sprinter that have a 1,000 lb tongue weight rating. Does this mean if I install one of those 1,000 lb tongue rated hitches I can now carry 1,000 lbs of tongue weight on the Sprinter (using weight distribution) as long as I don't exceed total payload? Would I void any warranty? Incur liability in case of accident caused by failure?
Towing experts? Sprinter experts? @Maslin @Midwestdrifter @Mr. Bills ?
PS I am asking for someone else, I only flat tow a Jeep. I think I know the answer but others are saying different.
Pretty sure I found it right here on the forum
I just went through my manual with regards to towing and it doesn't mention anything for or against using a weight distribution hitch, or otherwise mention the concept of such a thing existing, AFAICT. @Maslin sorry to call you in to this, but is there an official line on the subject?
I don't think unibody is crucial part here.
Modern SUV are unibody and they can use WD hitches, but in Sprinter case, you have very long overhang and that makes the difference.
Just as a pointer, 3500 long Sprinter do have 6000lb towing rating, but extended version, who add about 16" is dropping it down to 5000lb.
Once you start checking, most of Diesel Pushers, who can weigh 15 tons, do have 5000lb rated tow hitches.
Long overhang with heavy engine in it is not leaving much margin for extra weight.
Here it is, post #15 https://sprinter-source.com/forums/index.php?threads/50725/ FWIW I thought WD on a unibody was a bad idea myself but I have been researching for 3 days and found quite a few unibody vehicles where the manufacturer allows it.
But the 'catch' is in the quote you linked to...
A trailer hitch must be categorized as Class III, IV or V to be used with a weight distribution system. Not all Class III hitches are designed to be used with weight distribution systems, though. Always check the weight rating label that is on the trailer hitch. This sticker lists two capacities: weight carrying and weight distributing. If nothing is listed for weight distributing, then a weight distribution system cannot be used.
So has your/the hitch in question actually got a weight rating listed specific to a WDH? If not then this says you CANNOT use a WDH with it.
Which modern SUV are you discussing?
But OE hitches do have 7 or 8" limit from the receiver to the ball. Good luck finding WD setup, who meets it.
I never used WD hitch period.
IMHO WD is BandAid for poor tow vehicle design, like American pickups, who squat like crazy with bigger grocery load.
I sit corrected. I have never heard of a unitary construction vehicle permitting this. Just out of interest, where is this located?
All Sienna’s and this I assume Highlanders allowed it. Honda didn’t recommend it on the Odyssey because that had such little extra capacity on the front axel.
and really a WDH for tongue weighs less than 500 pounds doesn’t transfer all that much weight to the front axle. Some weight distributing hitches are also anti sway. Those I would use on a lighter trailer.
Back
