Hi Fellow Sprinter Punters,
I'm new to forums so please bear with me.
My actual vehicle is a Motorhome (only 47500K genuine miles) - 1999 Mercedes Hymer S520, which I believe is model 312D (not absolutely certain). Its a sad story as we've spent pension funds on the purchase and now its looking like we can't use the vehicle due to not being able to fix or replace ignition parts.
The Problem - Intermittent NO CONTACT and failure to turn the starter motor - dash lights are lit and power to radio. On fully turning key dash/ignition light has momentary millisecond flicker, remains lit but there's no contact or start. I've read this could mean overloaded/worn/failing switch contacts, suggesting the switch needs replacing - but that doesn't necessarily help me.
Action so far - Northsidetruck&Van Leeds replaced the ignition cylinder barrel in July 2025 and reprogrammed with 2 x new Transponder keys. It seemed okay initially but I was never 100% confident in the fix as there was the isolated failure which I put down to anomaly, or the way I turned the key. However there is now no doubt the original problem is unresolved (in Nov 2025) : the key/ignition now feels exactly the same as before the Northside intervention and there is a less than 50% probability of a successful start and ignition contact. (The fact the assembly was 'disturbed' and refitted probably accounts for why it functioned with less issue for a short while - but its had extremely little use since July). Northside have washed their hands so to speak (long story there - unbelievably poor service and other damage caused).
Help and Advice Sought:
1. Can anyone confirm the sprinter model details of my 1999 Hymer S520?
2. Has anyone else experienced this issue with ignition failing to contact while power is available to radio etc?
3. Has anyone successfully obtained and changed the electrical ignition switch that mounts on the end of the housing?
(Is the above a push fit clip in plastic switch or is it fixed with bolt/screws and what is the part number?)
4. Has anyone successfully obtained and changed the full ignition assembly i.e. housing including electric switch and ignition barrel with new recoded keys.
5. Can anyone recommend a competent Garage (as near Leeds West Yorks UK as possible please)
6. Where can I obtain parts and how can I be certain they are correct?
PLEASE PLEASE HELP if you can.
MrUBolt.
MrUBolt.
