Thanasis
I replaced the bucket I used to put on the ground under the van to collect the gray water with a "holding tank" , actually a Rubbermaid 6 gallon water tank which I painted black -- it was blue (last photo) fitted appropriately and strapped under the floor on the driver's side. I did not want to drill holes through the floor to hang the tank. What I did is drill 2 holes on the floor rib and attach an horizontal bar to anchor two vertical 2'' straps, and a bracket on the wall to anchor the horizontal 1" strap ( first photo )
The drain hose comes down through the factory-provided access opening, which was blocked with a grease-saturated piece of foam , and which I replaced with the cover shown on the second photo.
The tank is drained via a faucet installed on an 1.5" rubber cap.
Thanasis
Thanasis
