Fluid leaking onto driver side subframe…
MidnightFrog
I was doing a walk around of my van yesterday and noticed some fluid on the ground and all over my lower subframe and suspension on the driver side of the vehicle. The van is a 2016 4x4 and recently had a 2” Van Compass lift added to the front.
At first I suspected the boost hose, which had gotten a lot of attention on this forum, and fluid is certainly dripping from that. But there are another couple hoses near the rear attachment of the boost hose and one of them doesn’t look seated well.
I’d love insights on what these hoses are and if this is an easy “push it in” type of fix or worse.
Images attached showing what I think is the issue. The red wire is directly above the lower arm mount and you can see the lift spacer.
MidnightFrog
Looks like I might have figured it out. One of the power steering fluid lines above was leaking, which I believe caused the problem. So I think case closed!
