2008 water pump part number help VIN WDWPE745885254078
aglicknmex
Dang... I was able to get all of the parts ordered today thanks again
My thermostat and intake manifold is not like the per VIN diagram.
I could use the housing and thermostat but the gaskets are shot.. last mechanic to work on it probably couldn't find the part either and slobbered it all up with silicone to make it work
aglicknmex
Thanks for the part numbers Ivan!
The thermostat page does not match mine. The intake manifold and thermostat housing are different. I have reused my old one.
is it possible I would need to replace the intake manifold with the new style in order to use current parts??
What a time bomb this 08 was!! water pump and fan support had rough bearings!
Also the tensioner idler was bad, and one of the small black idlers.
4 chances to fail!!
All new OEM parts installed
