Warranty Claims being Denied by MB........... ?
OrioN
2008 2500 170" EXT
:hmmm:
Just popped up on me FB feed.....
Heads up and fair warning: I was just informed that as of today Mercedes is tightening the screws on warranty claims for “upfitted” vans. If you have a van that was not upfitted by a “certified Mercedes upfitter” of which there are only a few nationwide, your van will be labeled as “R status” which ostensibly voids your drivetrain warranty.
How this came up for me was a recent Van Compass suspension upgrade disqualifying me for a pre existing rear differential issue. I’d suggest contacting your local dealer to have a conversation on strategy before making any warranty claims.
:hmmm:
How did they say a suspension mod affected the differential? That seems a stretch. Did the angle of the driveshaft change? Was there an actual change to the differential, like changing the cover?
All that said, there is something to doing major mods to an older vehicle out of warranty.
Regards,
Mark
Based upon other posts on Facebook by the same guy, my take is that one particular dealership is giving him a hard time, not MB corporate.
Not even Mother Benz can make the Magneson Moss Consumer Protection Act disappear.
Status R is not a voided warranty. It is manual review from the VAOM prior to warranty work being performed. If your suspension, wheels and tires are modified and you complain about a differential noise I would expect pushback.
There are Winnebago vans that have a status R due to a fuel line connection Winnebago performed outside BEG specifications. That’s an approved upfitter if there ever was one.
Based upon other posts on Facebook by the same guy, my take is that the Bend dealership or a regional rep is giving him a hard time, not MB corporate.
I live in Bend and they absolutely will grill you about your modifications and then will recommend to MB to deny warranty for any areas of the van that you have touched/modified.
Not the first time I heard of the similar stories on MB brand, which held me back from upgrading the 17" aftermarket wheels TBH.
I saw MB Lynnwood service shop selling Method 17" wheels with 245/70/17 tires, I know it's not the same apple to apple comparison, but I ended up getting the same size of aftermarket 17" wheels + tires as well, owl talons + falken wildpeak a/t4 to be specific.
I'm going to wait 'til the warranty expires to upgrade the other suspension components.
Denying warranty on modified bits is pretty standard. Adjacent attached parts is hit or miss. MBs goal is to avoid warranty claims when possible. Dealers don't like to do warranty work as it pays a lot less. So often dealers will deny a warranty out of hand. Often never even bothering to submit the claim up to MB.
I know everyone's build goals and use cases are different, but for my case, which is road trips and very occasional mild off road activities, the OEM AWD and ride height are more than adequate so I don't feel the need to modify anything under the van. As far as the interior build, the ONLY place I am considering touching the OEM systems is a DC2DC charger between the start battery and my DC electrical system. A flip (or turn) of a shutoff and there is no connection between my build and the OEM systems. Zero, butkus, nada, zippo, niente.
So I am ready to defend my case to MB should the need arise.
Make sure you don’t connect to the battery, use the fuse box under the seat. It’s all in the BEG.
This +1000. I see so many posts of people wanting to connect straight to the battery (positive and/or negative) because some aftermarket company recommends it, but there are very clear guidelines in the BEG that shows the proper way to do it. I think my 2021 van actually came with a supplemental hard copy manual that showed the appropriate connection points. Regardless, the BEG should be mandatory reading if you are converting a van or adding accessories (in my opinion).
And that doesn't mean you have to follow the BEG to the letter, but at least you are making more informed risk/reward decisions if you choose to violate MB recommendations. As far as warranty claims, suspension is always going to be a red flag, particularly if a lift is involved. And as good as some of these aftermarket suspension kits are, you can't expect MB technicians at the dealer level to evaluate whether the kit is changing geometry, etc. A lot of it's going to come down to dealer discretion (as simple as whether the tech is feeling grumpy that day or not).
I hope this is just a case of a dealer being a dick.
Unrelated:
Looks like the van is a 2024 with the factory crease in the upper panel to resist oil canning.
Wondering how the install went on that little slider window up there, seems like it’d be challenging to get a good seal.
Unrelated:
Any support case to Mercedes requires a list of modifications and photos.
You have a vibration, there's and LI that requires a case to be opened... you see where this is going.
Modifying any vehicle under warranty has always been a gamble. Jeeps, Mustangs, Subarus, Evos, anything. The old days were guys spending hours putting their cars back to stock just to take them in for a recall or warranty work. Try that with a Sprinter.
While I’m pretty sure MB lawyers can beat up most John Q. Public’s lawyers, the Magnuson-Moss act puts the burden on a vehicle mfg like MB to prove a mod caused a problem if things went to court.
But that doesn’t help anyone that needs a repair done immediately.
MM act is next to worthless. How can a little guy go up against MB in court? MBs pockets are too deep.
I get the intent of the MM act though.
YES
I state this because have booted AND lost count of how many claims that didn't meet the TERMS AND CONDITIONS of warranty support
Probably the next course of action is "never" give a business to this particular brand, otherwise just dance along with the music they play.
We all have choices to buy and not to buy.
This one may be dealer specific if it's Bend Oregon's dealership. I had a OEM serpentine belt put on by the Eugene dealership that failed in 3 months. MB parts warranty is 2 years. Since I was 45 miles from Bend, I had the Vechicle towed to Bend and replaced for $800 and to thier credit, done the same day. They would not honor the warranty on the belt even though I had records with me to show the belt replacement date. I worked with them for a month or so and their claim was the area rep. would not honor the warranty. I went back to Eugene and they tried to work with Bend which was resolute on note honoring the warranty. Eugene dealership not only honored the warranty but also paid the $750 towing bill incurred to the Bend dealership. Kudos to the Eugene service group. Lesson learned, was to carry a huge wad of cash if I stray far from home.
:thumbup:
Bend people should go back to making the drive over the hill.
Back
