Replacing brake lines
djb377
2006 2500 SHC Passenger
I agree with Cheyenne. On any vehicle I've owned, I just abandon any difficult areas and route around. Typically, I've found the long run from front to back rusts out first. I leave the old line attached and cut off at either end of the repair and use tye wraps at the frame/body clip points to secure the new line. If the lines are rusted, usually the clips are too. And fooling with them too much, causes them to break off. I never try to match the OEM bends if I don't need to and any universal line length that's too long, I just loop or create extra radius to take up the extra length. I route new lines tucked up to avoid being caught/snagged by whatever on the road. I'm not building a show car. Never had a problem in 40+ years of working on my vehicles. But I can understand that if you're paying a garage, the expectation is a close to OEM installation and the signature of professional work.
And I'm a big propionate of proactive rust proofing!! I've used wheel bearing grease cut with used motor oil, brushed
on the lines with a paint brush for years or lately I've used that new product by PB Blaster called Surface Shield. I'd like to explore the Fluid Film method Midwestdrifter suggested (I don't mind black oily mess on my undercarriage). My lines typically last 20yrs before replacement. My vehicles sit outside uncovered too.
Thanks. I have a small fuel tank leak so they're gonna drop the tank anyway. Appreciate the feedback!
JRiNVENTOR
2006 T1N 3500
We make them, its just a routine job that has been prevalent in the heavy truck/bus repair business for a century or more!
Can I purchase a couple rear lines from you? I have a 2006 3500 T1N. The nuts at the caliper are gone - rusted away. The others have been replaced already
JRiNVENTOR
2006 T1N 3500
Let me chack to see if we have some good take offs first.
Perhaps it would be better that I make my own? I just made a thread w a picture. I don’t know the name of that block before the final segments of line…I’m on my phone the shop manual is on my computer so I’ll get back soon
JRi
