Mr. Xtremities
Hello, experts. A bit of a newbie here but learning fast.
2006 Dodge Sprinter 2500, OM647 engine. Only about 150k miles but difficulty with a dead glow plug that I left alone for several years and wrestled with unexplained LHM. Finally learned that those glow plugs are more important than just getting the engine started! (First diesel.)
Glow plugs were stuck (of course), and broke a couple. With a couple leaks I decided to bite the bullet and do the head job. (A local shop wanted $6k to do it...)
Significant oil leak at the back passenger side which I hear is not unusual and a leak at the exhaust manifold was bigger than I expected. For the exhaust leak - at cylinder one/front - I am wondering if the weight of the turbo not being really well supported aside from the exhaust manifold and exhaust pipe put too much stress on that part of the manifold and caused the leak. BTW, the exhaust bolts / nuts were not terribly difficult to remove. Probably because this is still "low mileage" for a diesel.
Shall I just sand the exhaust manifold back to a smooth surface (i.e. to 800 grit as I did with my son's ranger) and use a calibrated edge to ensure all ports are in the same plane? And should I find a way to more securely hold the turbo in place? Pics attached.
(Will be removing & lapping the valves and checking the mating surface w/ a calibrated edge before taking it to a machinist to get the remaining 3 glow plugs out.)
(This after cleaning off the port somewhat.)
(The oil leak after head removed, for reference. Presuming the new gasket and an assured flat and/or re-cut mating surface will eliminate this upon rebuild.)
