Hello guys,
I just set off on a long trip and about 500 miles into the drive, I was put into LHM with no boost and lots of black smoke from the tailpipe. Also, for context, in the past few months I’ve noticed a more than usual amount of black smoke from the tailpipe with heavy acceleration to the point where I was afraid to accelerate quickly if there was a cyclist or a hippie behind me. With my scanner I cleared these codes:
P1403-1 EGR valve - positioner signals fault. Stored.
P1354-32 - synchronization between camshaft and crankshaft - plausibility. Stored.
P1470-4 - charge pressure control valve - cable has short circuit to positive. This was the only stored/current code I had after restarting the van when I arrived at my destination. I hadn’t checked my scanner in months so I’m not certain if the other two codes came about during this LHM event or not.
I had an extra intake air temperature sensor and replaced that. It was oil soaked and looked beat up. I then used contact cleaner to clean the MAP sensor and EGR connector as well as tightened all the turbo hoses. The next day I drove another 500 miles with no issues and no recurring codes. However I do notice an exaggerated whooshing sound that leads me to believe there is a breached hose in the boost system. When I inspected the turbo hoses, the one on the passenger side from the intercooler to the bottom piece of the plastic mid-section is caked in oil and carbon. The upper hose after the plastic mid-section has always been pretty loose at the EGR connection. Service records for the van when I bought it privately don’t show maintenance on these parts, but I can’t be certain of how reliable records were kept. So this brings me to my question.
luckily I have arrived at a friends house in Delaware and am able to spend a week here waiting on parts from Europarts-SD. Here are the part numbers I took off my 2003 OM612:
Turbo to intercooler:
901 528 52 82 (Type B according to europarts)
Intercooler to EGR/ intake (part # taken from lower hose section):
901 528 53 82
The problem is, when I look at the euro parts website, the part number I pulled from the intake-side hose is matched with the OM647 engine. But when I look at millionmile sprinter, he mentions the OM612 engine has two different intercooler sizes and thus different accompanying hoses. Can I rely on the numbers I pulled from my van or did a mechanic install the wrong hoses at the intake side at some point? Is it possible for a OM612 vin to use the same intercooler to
intake hose and possibly intercooler as a OM647 vin? I’m certain my intercooler is factory and the turbo to intercooler hose looks old and factory as well. The intercooler to intake hose looks newer at the intake end but the bottom end is so coked in carbon is hard to tell.
Trying to nail this down throughly and get my parts order from europarts finalized before I make for the western states as I won’t have another opportunity to chill for a week before I have to be in CA by early August.
Also, if you guys have any general insight into what could be throwing the codes I received, I would appreciate hearing it. Thanks a lot.
Lou
901 528 53 82
Lou
