marklg
When significantly obstructed, the ping success rate is more telling than an instantaneous speed test. If you run 100 speed tests, you will get 100 different numbers, some of them very bad or even fail to connect. That is not necessarily bad as the outtages may only last a few seconds. Streaming will buffer up and you probably won't notice. I'm using it as a mobile office doing Teams calls, so putting it on the roof limits the outages.Tossed on the dash in the driveway. In the trees, way out of alignment, zero effort.
Here is the ping rate for when it's highly obstructed, only 2.28% ping success. But the DNS requests are at 95% because it can wait for an answer for those, probably even minutes till the next connection.
As to the various plans, face it, if you compare to what you pay for cellular service, it's a bargain for much better throughput and availability. They virtually have no real competition and don't act like the big three cell companies which theoretically at least have competition. I have an older Verizon plan that they gauged $20 for each 1 GB overage. I also have a Visible phone, that is only $25 a month, but speed is often barely more than the Starlink $5 plan. The $5 plan provides more than an Inreach $15 plan. You can always share your location on whatever you are connecting with. For those with a Yacht or Private Jet, their plans are still way less than Iridium or Inmarsat with way more throughput.
I have not seen cost comparisons, but I bet their reusable launchers provide a cost at or below the cost of planning, getting approvals for and building cell towers and getting a backhaul and power to each one.
Regards,
Mark
