Big Red Sprinter
Hey guys, I plan on changing the transmission oil and filter on my 06 sprinter and need a Tranny dipstick. I know euro parts sells one for $50.00. Is there any other recommend shops that sell this item for less. Thanks
Even if you find a genuine, appropriate tool, Steve at europart-sd.com's customer service is worth a premium (but I do doubt you'll find a more fair price).
-Jon
Don't know which specs you're referring to, but the MB dipstick doesn't bottom-out on the inside surface of the pan, it rests on a shoulder above the measuring area. So, if you do assume it bottoms out on the pan, and use the measurements of the service manual, you are low on fluid. On the other hand, if you are aware, what is your depth correction figure? Or, what is the diameter of your shoulder?If money is an issue, make your own like I did, with specs listed on here, using aircraft wire from building store for $1.00.
My kind of guy..... I think being overly concerned about the NAG1 fluid level is a hang on from old. (I also jack my Sprinter using the differential case with a floor jack.) Get it near the full mark... not over... and everything will be fine.
My opinion and worth everything you'll pay for it. vic
Since I'm trying to minimize repair effort & cost, I would never make a modification to my tranny without personally and fully understanding all the possible effects.(you really should order the DARF kit from Doktor A if you haven't)
SRT has recently reported a tranny failure. But maybe it doesn't meet your definition of disastrous. I remember reports of more; if you're interested, you could search here. If they don't fail, where does the supply of rebuilt units come from?... and lack of disastrous failure posts on the forum(s) for the NAG1 transmission ...
Given my experience and background I know I am not capable of ever "personally and fully understanding all the possible effects" of a modification to an NAG1 transmission. From the ability demonstrated by him over time here and on other forums I have faith that Doktor A does. The fact that he came up with the DARF solution is of itself testimony. My opinion (read that as "guess") is that perhaps RSN contributes to harmonic balancer failures so I think getting rid of the RSN is worthwhile. Not to mention that the tranny just seems so much smoother after the mod.Since I'm trying to minimize repair effort & cost, I would never make a modification to my tranny without personally and fully understanding all the possible effects.
Well, OK. I didn't mean to indicate that they never fail, but NAG1 transmission failures are not an Achilles heel for the vehicle. Most tranny failures I recall are high mileage units which are to be expected.SRT has recently reported a tranny failure. But maybe it doesn't meet your definition of disastrous. I remember reports of more; if you're interested, you could search here. If they don't fail, where does the supply of rebuilt units come from?
Subscribe to www.sprintertekinfo.com and you'll see that hoisting by the differential pumpkin is "blessed" by MB.(I also jack my Sprinter using the differential case with a floor jack.)
The '03 service manual says:Subscribe to www.sprintertekinfo.com and you'll see that hoisting by the differential pumpkin is "blessed" by MB.
I've seen John Bendit use an air jack to life a giant Sprinter 3500 RV by the diff housing. I'm not sure where the idea of not lifting by the "pumpkin" came from, but I think it's an urban myth, debunked by John and SprinterWIS.
-Jon
Exactly. And the "pumpkin" is connected to the springs (which support the weight of the van) by long pieces of this same thin walled tubing.thin walled tubing tends to crush and bent easier.
(they put that boxed warning twice on the page, once for 11000 GVW, and once for the lesser weights.)CAUTION!
Do not position the jack at the leaf spring or the differential housing.
Geez Jon,...
-Jon
... but, this "thin walled" tube (no thinner than many other vehicle axle tubes by the way) is pressed into socket fittings so when the differential case (pumpkin) is lifted the stress is transferred over to the spring assemblies through that strong socket fitting. A tube shape is very strong. The reason it's never good to jack against an axle tube in the middle is that you can point load it which will then deform and weaken the tube.Exactly. And the "pumpkin" is connected to the springs (which support the weight of the van) by long pieces of this same thin walled tubing.
That statement is in the operator manual where they are specifically describing using the OEM bottle jack for lifting a Sprinter. That warning is never repeated in service books that I've seen anywhere for lifting a Sprinter using other than the OEM jack. Why would it be?From page 205 of my 2005 Owner's Manual:
CAUTION!
Do not position the ... OEM ... jack at the leaf spring or the differential housing.
it could be that they're referring to the use of the comes-with-car bottle jack in that position.
