Graphite Dave
Dave Orton
Working on my Transit conversion drawings. I have collected the connectors that will be used and put them on two drawings which are attached. 80/20 does not make equivalent connectors of the same thickness or hole spacing for some of my applications so I make my own out of flats and angles. Notes on the connectors:
A. This is my standard angle connector. 3/16" thick, 1 1/4" long and offset holes. Offset holes allow use of two carriage bolts at the joint with space for the nuts.
B. This is an offset angle connector that allows a 1/4" panel to be used.
C. This connector with one leg of angle short is used in my floor to cleat the 3/8" rubber floor.
D. Double height angle connector used to anchor cabinets to the 80/20 floor.
E. Standard angle connector with one hole offset to allow use of carriage bolts.
F. 3 hole flatbar connector.
G. Mounting angle for 1/4" removable panel.
H. Standard 80/20 end connector.
I. Less expensive and better way to get a tapped hole in a 80/20 slot. 5/16" set screw holes economy nut in place. Economy nuts are cheap compared to other choices.
J. Wood fixed panel connector.
K. 1/8" thick 3 hole connector plate.
L. 1/8" thick 4 hole connector plate.
